Glynn Clements wrote:
I forgot that the --enable-largefile switch only enables LFS in
libgis, not anywhere else.[Although config.h includes definitions to enable LFS automatically,
those definitions are currently inactive. This is probably a good
thing; a lot of GRASS' code isn't LFS-aware, and explicit failure is
preferable to silently corrupting data.]To enable LFS elsewhere, you need to manually add
-D_FILE_OFFSET_BITS=64 to the compilation flags. The simplest approach
is to add:ifneq ($(USE_LARGEFILES),)
EXTRA_CFLAGS = -D_FILE_OFFSET_BITS=64
endifto raster/r.in.xyz/Makefile, then repeat the "make" and "make install"
steps.
I have added this knowledge (and some other tips posted to the mailing
list by Glynn & Brad) to a page in the Development section of the Wiki.
Please correct, update, and expand as needed.
http://grass.gdf-hannover.de/wiki/Large_File_Support
how hard will it be to get a HAVE_FTELLO (or whatever) switch tested &
set by ./configure? If we get that, should every LFS compliant module be
written like:
#ifdef HAVE_FTELLO
off_t filesize;
#else
long filesize;
#endif
#ifdef HAVE_FTELLO
fseeko(in_fd, 0L, SEEK_END);
filesize = ftello(in_fd);
#else
fseek(in_fd, 0L, SEEK_END);
filesize = ftell(in_fd);
#endif
Or is that better handled in G_fseek() etc fns etc as suggested by Brad?
(still should try and match variable type in that case (how?))
fopen() and fclose() are ok in both cases? (dependant on finding
-D_FILE_OFFSET_BITS=64 in the Makefile and including grass/config.h ?)
I'm trying to make that wiki page a "best practices" guide for GRASS
developers, so direct updates there would be appreciated.
Hamish
