[GRASS-dev] Re: [GRASS-user] r.out.gdal bug? problems with createopt
preparing the patch, I realized there is something strange, createopt
works only using MEM driver...
GDALCreateCopy, works:
  /* Finaly create user required raster format from memory raster if
in-memory driver was used */
    if (hMEMDS) {
  hDstDS =
      GDALCreateCopy(hDriver, output->answer, hMEMDS, FALSE, papszOptions,
         NULL, NULL);
  if (hDstDS == NULL)
      G_fatal_error(_("Unable create raster map <%s> using driver <%s>"),
        output->answer, format->answer);
GDALCreate(), createopt seems to be ignored(?)
  hDstDS =
      GDALCreate(hDriver, output->answer, cellhead.cols, cellhead.rows,
           ref.nfiles, datatype, papszOptions);
Martin
2007/9/24, Markus Neteler <neteler@itc.it>:
Markus Neteler wrote:
> Hi Robert,
> it seems to be the same bug as it was found and fixed in v.out.ogr
> some days ago by Martin.
> I debugged a bit and found that the second part
> "PROFILE=BASELINE" isn't passed. It gets lost in
> main.c, line 554.
> v.out.ogr's main.c (line 249 etc) has a working solution
> but my try to port it to r.out.gdal failed (no idea why, should be
> rather easy - but it segfaults for me).
What about moving this multi-option code to
G_store_multi() or something like this?
Modules with multi-option parameters are
- r.out.ogr
- v.out.ogr
- v.transform (new column parameter)
- maybe others
View this message in context: http://www.nabble.com/r.out.gdal-bug--problems-with-createopt-tf4504650.html#a12855513
grassuser mailing list
grassuser@grass.itc.it
Martin Landa <landa.martin@gmail.com> * http://gama.fsv.cvut.cz/~landa *
According to CVS this was fixed:
2007-09-24 12:13 martinl
        * main.c: Parse 'create options'. Message cleaning.
Thanks, Martin. I guess I/someone should backport that to GRASS 6.2?
Martin Landa-2 wrote:
    if (hMEMDS) {
  hDstDS =
         NULL, NULL);
  if (hDstDS == NULL)
  hDstDS =
Martin
View this message in context: http://www.nabble.com/r.out.gdal-bug--problems-with-createopt-tf4504650.html#a13150236
Nope, r.out.gdal in 6.2 is the shell script version using gdal_translate & the
GRASS plugin. r.out.gdal(.c) is new for 6.3.
Hamish
____________________________________________________________________________________
Need a vacation? Get great deals
to amazing places on Yahoo! Travel.
http://travel.yahoo.com/
