[->dev list]
Michael Barton wrote:
I'd forgotten about this environmental variable. So I tried it out to
remind myself how it worked. Overall, it isn't much of an advantage,
at least in the case of r.reclass and absolutely will not work in the
TclTk GUI.
? try r.digit.
What is does is put the command back into the old interactive terminal
mode.
Only IF you don't don't enter the options at the command line.
No GUI means no GUI at all.
So for r.reclass, if GRASS_UI_TERM=0, you need to type ...
r.reclass input=[old_map] output=[new_map]
...to get to the interactive terminal screen where you can put in
reclass statements.
yes. and if you type "r.reclass" without options you get the GUI window,
which tries to output the terminal/curses "gui" in the gui output box.
If GRASS_UI_TERM=1 and you simply type r.reclass, you are prompted in
the terminal to enter the [old_map] and [new_map] before you can get
to the same terminal screen to put in reclass statements.
yes, but you don't get those prompts if you gave them on the command
line.
Because it requires interactive xterm use (query/response), it cannot
be used in the TclTk GUI platform.Oh well.
no more than r.digit or any other module that is launched with
-command {term g.module }
It is a very useful module, IMHO, because it offers the chance to
maintain multiple views of a raster map and use only a tiny bit of
disk space.
it requires an term to run (like r.digit), but if fed reclass rules via
stdin it can run in non-interactive mode. e.g.
G63> r.reclass input=[old_map] output=[new_map] < rules.txt
G63>
I though this is what $GISBASE/gm/script/r.reclass.rules and
r.reclass.file for?
The problem:
r.reclass by itself on the command line launching a GUI breaks when you
hit [Run].
The solution: GRASS_UI_TERM=1 + wrapper scripts (wappers provide gui
frontend for gis.m with no breakage from the command line)
$GISBASE/gm/script/r.reclass.rules and .../r.reclass.file
GRASS_UI_TERM=1 should not break your wrapper scripts.
Hamish
