[GRASS-dev] Re: [GRASS-user] r.reclass not spawning xterm on Mac OS X
> Michael Barton wrote:
> You have to run r.reclass with arguments to get to the xterm
> interface. From the GIS Manager, there is a script that does this.
> Running r.reclass without arguments will open a GUI that is pretty
> useless.
I have modified r.reclass and r.recode in 6.3-CVS to force interactive
term mode if they are run without arguements. The GUI wrapper scripts
should not be affected. Let me know if they don't.
A couple of potentially useful enhancements:
1. Add a rules= option to r.reclass which accepts the name of a file
containing reclass rules.
2. Add a button to the standard dialogs which allows stdin to be
redirected from a user-specified file.
Either of those would allow r.reclass to be usable without a terminal.
this is exactly what Michael's two wrapper scripts provide.
There's still the general issue of what we do about
terminal-interactive modules. So long as at least one such module
exists, the issue remains.
Either we decide to "kill them all",
not until functionality is ported to something newer, or analysis method
is conisdered obsolete. (does anyone use the i.class stuff?)
and declare all use of stdin to be a bug,
stdin is very useful for scripting use. the problem is exclusive input
via stdin (or interactive term) and no option to take from a file. you
can have input from a file as the primary method and still allow the
module to take data from stdin.
or we need some way for a module to indicate that it needs (or may
need) a terminal. The latter is complicated by the fact that a module
may only require a terminal in certain circumstances.
It's not a full solution at all, but see above r.reclass commit.
Comments? Please. I'd *really* like to get this issue dealt with; it's
been coming up since the days of d.m (maybe even since tcltkgrass).
trying to get a list of remaining modules:
r.le - in the process of being replaced by r.li
r.digit - just a frontend to r.in.poly, easily replaced by a wxPython
  utility (integrate with wxPython version of v.digit as g.digitize?)
r.watershed - all sorts of interactive menus in shed/ which I'm not sure
  how to access.
r.support - being worked on by Brad
i.* are the main apps without a solution in progress.
$ grep -rI G_ask * | cut -f1 -d: | uniq
general/g.setproj/get_datum.c
general/g.setproj/main.c
general/manage/lib/ask.c
general/g.ask/main.c
include/P_site.h
include/gisdefs.h
lib/gis/ask_vctrs.c
lib/gis/ask_cell.c
lib/gis/nme_in_mps.c
lib/gis/ask.c
lib/gis/get_ell_name.c
lib/gis/gislib.dox
lib/gis/get_projname.c
lib/gis/gisvectorlib.dox
lib/gis/get_datum_name.c
lib/gis/parser.c
lib/gis/gisrasterlib.dox
lib/imagery/sigfile.c
lib/imagery/sigsetfile.c
lib/sites/sites.c
raster/r.le
raster/r.watershed
raster/r.support
raster/r.coin/inter.c
raster3d/r3.showdspf/r3_find.c
raster3d/r3.mkdspf/r3_find.c
$ grep -rI '$(VASKLIB)' * | grep Makefile | cut -f1 -d:
general/g.mapsets/Makefile
general/g.access/Makefile
imagery/i.cca/Makefile
imagery/i.ifft/Makefile
imagery/i.gensig/Makefile
imagery/i.group/Makefile
imagery/i.his.rgb/Makefile
imagery/i.zc/Makefile
imagery/i.rgb.his/Makefile
imagery/i.rectify/Makefile
imagery/i.target/Makefile
imagery/i.smap/shapiro/Makefile
imagery/i.gensigset/Makefile
imagery/i.cluster/Makefile
imagery/i.vpoints/Makefile
imagery/i.fft/Makefile
imagery/i.maxlik/Makefile
imagery/i.class/Makefile
imagery/i.points/Makefile
imagery/i.ortho.photo
imagery/i.pca/Makefile
lib/init/Makefile
lib/edit/Makefile
lib/imagery/Makefile
ps/ps.map/Makefile
raster/r.le
raster/r.support
raster/r.digit/Makefile
vector/v.transform/Makefile
Hamish
Am I understanding the proposed changes correctly? They will make no
difference for how the current wrapper scripts operate with r.reclass (and
related files), but will will make them functional--albeit in the old xterm
interface--when run from the command line without arguments. This will serve
as an interim solution for keeping these modules functional while the old
interactive xterm modules are being phased out.
Is this the gist or did I miss an important point?
Michael
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
Date: Fri, 10 Nov 2006 17:36:02 +1300
To: <michael.barton@asu.edu>, <glynn@gclements.plus.com>,
<dechant@nature.berkeley.edu>
Cc: grass5 <grass-dev@grass.itc.it>
Subject: Re: [GRASS-user] r.reclass not spawning xterm on Mac OS X
useless.
  how to access.
include/P_site.h
include/gisdefs.h
lib/gis/ask_vctrs.c
lib/gis/ask_cell.c
lib/gis/ask.c
lib/gis/gislib.dox
lib/gis/parser.c
lib/sites/sites.c
raster/r.le
raster/r.watershed
raster/r.support
lib/init/Makefile
lib/edit/Makefile
ps/ps.map/Makefile
raster/r.le
raster/r.support
Hamish
[r.reclass, r.recode assert GRASS_UI_TERM=1 in the C code]
(and related files), but will will make them functional--albeit in the
old xterm interface--when run from the command line without arguments.
This will serve as an interim solution for keeping these modules
functional while the old interactive xterm modules are being phased
out.
Yep, the change should only affect r.reclass,r.recode when called from
the command line directly, and prevent the interactive session from
trying to exist in the GUI output window.
everything else (including wrapper scripts) should work ok without
futher modification.
Hamish
