[GRASS-dev] Re: [GRASS-user] r.stats: negative cell counts and percentages
Hermann wrote:
svn up https://svn.osgeo.org/grass/grass/branches/releasebranch_6_4 grass64_release
not that it matters here, but do you use 32 bit or 64 bit
CPU+OS?
(on 8 Sptember 2009)
>> I have the following raster map:
>> Type of Map: raster
Number of Categories: 255 Data
Type: CELL Rows:
58000 Columns:
67000 Total
Cells: 3886000000
>> r.stats (-c and -p) tells me:
>> I guess there is an integer overflow somewhere(?)
Yeah, I think you are right.
There are many int++'s in raster/r.stats/stats.c
Perhaps those counters++ should be changed to "long long"?
what is the result of r.univar ?
I see r.univar has been modified to use int for number of cells
and number of non-null cells. (earlier versions used unsigned
int, why the change?) But 'unsigned int' for the counter just
postpones the problem a couple of years, maybe long long is
better there?
Like r.info, I think r.univar and r.stats are pretty fundamental
raster modules to have working correctly for this.
#32bit linux system/gcc
sizeof(long long) is 8
sizeof(long) is 4
sizeof(int) is 4
#64bit linux system/gcc
sizeof(long) is 8
sizeof(int) is 4
I notice r.info uses unsigned long long + printf %llu
Shall we standardize on that? If it can be done without
dealing with --enable-lfs all the better, I'm pretty sure
that LFS has more to do with which 64bit friendly glibc
functions to use so not relevant. But I'm not 100% sure
about this stuff so I ask.
I'm guessing that off_t should only be used for addresses,
or if all else fails can it be repurposed?
Hamish
... and g.region uses an #ifdef:
#ifdef HAVE_LONG_LONG_INT
            fprintf(stdout, "%-*s %lld\n", width, "cells:",
                    (long long)window->rows * window->cols);
            if (print_flag & PRINT_3D)
                fprintf(stdout, "%-*s %lld\n", width, "3dcells:",
                        (long long)window->rows3 * window->cols3 *
                        window->depths);
#else
            fprintf(stdout, "%-*s %ld\n", width, "cells:",
                    (long)window->rows * window->cols);
                fprintf(stdout, "%-*s %ld\n", width, "3dcells:",
                        (long)window->rows3 * window->cols3 * window->depths);
#endif
Hamish
"long long" is C99, but provided by some C89 compilers as an
extension. Any use must be conditionalised upon:
Any "long long" values need to be printed with "%lld" ("%llu" for
unsigned), which also needs to be conditionalised.
The main downside is that you can end up needing a lot of conditional
code.
LFS has two parts: making off_t a 64-bit type, and redirecting I/O
functions to the 64-bit versions.
In order to make off_t a 64-bit type, there has to *be* a 64-bit type.
But that type will exist regardless of whether LFS is enabled.
off_t should only be used for file offsets. There's no advantage of
using it as a general-purpose integer type, as you need to convert it
to a standard type for printing, so you still need to check for the
existence of "long long" to determine which type to convert it to.
conditional code.
I'm not seeing any alternative though.
For any module which does math with it (eg casting prior to
variable multiplication/division), perhaps to save some noise in
the code the LONGTYPE could be set up as a macro at the top
of the file and then the casts should look like
(LONGTYPE)chellhd.rows * cellhb*cols
setting up strfmt=LONGFMT for %llu or %lu is a bit uglier, but
a number of other modules pull such tricks to aviod CELL/FCELL/
DCELL switch statements.
Hamish
> conditional code.
I suggest adding the following (or something similar) to config.h:
  #define longest long long
  #define PRILONGEST_PREFIX "ll"
  #else
  #define PRILONGEST_PREFIX "l"
  #endif
  #define PRIdLONGEST PRILONGEST_PREFIX "d"
  #define PRIiLONGEST PRILONGEST_PREFIX "i"
  #define PRIoLONGEST PRILONGEST_PREFIX "o"
  #define PRIuLONGEST PRILONGEST_PREFIX "u"
  #define PRIxLONGEST PRILONGEST_PREFIX "x"
  #define PRIXLONGEST PRILONGEST_PREFIX "X"
I'm unsure whether it's better to use a macro or a typedef for the
type. Using a macro allows the use of "unsigned longest" rather than
requiring a separate typedef (e.g. "u_longest").
I have no particular preference as to the name of the macro/type, or
whether to use upper or lower case for a macro (a typedef should use
lower case).
The PRI* syntax is intended to mirror the C99 macros from
<inttypes.h>. The definition doesn't include the leading "%", so that
you can include flags, a field width and/or a precision.
CPU+OS?
32
total null and non-null cells: -408967296
total null cells: -913132378
Hermann
Hermann:
fyi filed as bug # 771.
The problem and solution are known, so a fix shouldn't take too
long.
regards,
Hamish
