Hamish wrote:
Markus Metz wrote:
There were quite a few posts in the list about vista problems,
maybe you find some hints there. I'm only using Linux, can't
help there.
IIRC it was more generic memory problems which only showed up on
MS Windows. In those cases valgrind reported errors, just on
Linux they end up being benign.
valgrind reports on nc_spm_08 with elevation as input DEM for r.watershed:
RAM mode:
CMD="r.watershed elevation=elevation@PERMANENT threshold=3000 accumulation=elevation.acc drainage=elevation.dir basin=elevation.basin stream=elevation.stream --overwrite"
GRASS 6.4.0svn (nc_spm_08):~ > valgrind -v --tool=memcheck --leak-check=yes --show-reachable=yes $CMD
==26414== Memcheck, a memory error detector.
==26414== Copyright (C) 2002-2007, and GNU GPL'd, by Julian Seward et al.
==26414== Using LibVEX rev 1804, a library for dynamic binary translation.
==26414== Copyright (C) 2004-2007, and GNU GPL'd, by OpenWorks LLP.
==26414== Using valgrind-3.3.0, a dynamic binary instrumentation framework.
==26414== Copyright (C) 2000-2007, and GNU GPL'd, by Julian Seward et al.
==26414==
--26414-- Command line
--26414-- r.watershed
--26414-- elevation=elevation@PERMANENT
--26414-- threshold=3000
--26414-- accumulation=elevation.acc
--26414-- drainage=elevation.dir
--26414-- basin=elevation.basin
--26414-- stream=elevation.stream
--26414-- --overwrite
--26414-- Startup, with flags:
--26414-- -v
--26414-- --tool=memcheck
--26414-- --leak-check=yes
--26414-- --show-reachable=yes
--26414-- Contents of /proc/version:
--26414-- Linux version 2.6.27.15-c0.1 (mkkas@monster) (gcc version 4.3.2 20081105 (Red Hat 4.3.2-7) (GCC) ) #1 SMP Tue Feb 24 11:46:22 CET 2009
--26414-- Arch and hwcaps: AMD64, amd64-sse2
--26414-- Page sizes: currently 4096, max supported 4096
--26414-- Valgrind library directory: /usr/lib64/valgrind
--26414-- Reading syms from /home/metzm/src/grass64_release/dist.x86_64-unknown-linux-gnu/bin/r.watershed (0x400000)
--26414-- Reading syms from /usr/lib64/valgrind/amd64-linux/memcheck (0x38000000)
--26414-- object doesn't have a dynamic symbol table
--26414-- Reading syms from /lib64/ld-2.9.so (0x342D800000)
--26414-- Reading suppressions file: /usr/lib64/valgrind/default.supp
--26414-- Reading syms from /usr/lib64/valgrind/amd64-linux/vgpreload_core.so (0x4802000)
--26414-- Reading syms from /usr/lib64/valgrind/amd64-linux/vgpreload_memcheck.so (0x4A03000)
--26414-- REDIR: 0x342d817d30 (index) redirected to 0x4a07890 (index)
--26414-- REDIR: 0x342d817ee0 (strcmp) redirected to 0x4a07e50 (strcmp)
--26414-- REDIR: 0x342d817ff0 (strlen) redirected to 0x4a07b50 (strlen)
--26414-- Reading syms from /home/metzm/src/grass64_release/dist.x86_64-unknown-linux-gnu/lib/libgrass_gis.6.4.0svn.so (0x4C0B000)
--26414-- Reading syms from /home/metzm/src/grass64_release/dist.x86_64-unknown-linux-gnu/lib/libgrass_datetime.6.4.0svn.so (0x4E67000)
--26414-- Reading syms from /lib64/libz.so.1.2.3 (0x342FC00000)
--26414-- object doesn't have a symbol table
--26414-- Reading syms from /lib64/libm-2.9.so (0x342F000000)
--26414-- Reading syms from /lib64/libc-2.9.so (0x342EC00000)
--26414-- Reading syms from /lib64/libdl-2.9.so (0x342F400000)
--26414-- REDIR: 0x342ec81310 (rindex) redirected to 0x4a076f0 (rindex)
--26414-- REDIR: 0x342ec80e40 (strlen) redirected to 0x4a07b10 (strlen)
--26414-- REDIR: 0x342ec7c9a0 (malloc) redirected to 0x4a072d0 (malloc)
--26414-- REDIR: 0x342ec808f0 (strcpy) redirected to 0x4a07b70 (strcpy)
--26414-- REDIR: 0x342ec7a410 (free) redirected to 0x4a05fd0 (free)
--26414-- REDIR: 0x342ec810e0 (strncmp) redirected to 0x4a07d70 (strncmp)
--26414-- REDIR: 0x342ec808b0 (strcmp) redirected to 0x4a07df0 (strcmp)
--26414-- REDIR: 0x342ec7ce90 (realloc) redirected to 0x4a073f0 (realloc)
--26414-- REDIR: 0x342ec86f10 (strchrnul) redirected to 0x4a088a0 (strchrnul)
--26414-- REDIR: 0x342ec83890 (mempcpy) redirected to 0x4a08900 (mempcpy)
--26414-- REDIR: 0x342ec82d60 (memset) redirected to 0x4a087d0 (memset)
--26414-- REDIR: 0x342ec80700 (index) redirected to 0x4a07810 (index)
--26414-- REDIR: 0x342ec841d0 (memcpy) redirected to 0x4a07f60 (memcpy)
--26414-- REDIR: 0x342ec35d50 (putenv) redirected to 0x4a08ac0 (putenv)
--26414-- REDIR: 0x342ec80f30 (strnlen) redirected to 0x4a07ac0 (strnlen)
--26414-- REDIR: 0x342ec80540 (strcat) redirected to 0x4a078d0 (strcat)
SECTION 1a (of 5): Initiating Memory.
SECTION 1b (of 5): Determining Offmap Flow.
100%
SECTION 2: A * Search.
100%
SECTION 3: Accumulating Surface Flow.
100%
SECTION 4: Watershed determination.
100%
SECTION 5: Closing Maps.
100%
--26414-- REDIR: 0x342ec82500 (memchr) redirected to 0x4a07f10 (memchr)
--26414-- REDIR: 0xffffffffff600400 (???) redirected to 0x3802d09d (vgPlain_amd64_linux_REDIR_FOR_vtime)
--26414-- REDIR: 0x342ec811b0 (strncpy) redirected to 0x4a07c40 (strncpy)
--26414-- REDIR: 0x342ec83ea0 (stpcpy) redirected to 0x4a08560 (stpcpy)
--26414-- REDIR: 0x342ec7c600 (calloc) redirected to 0x4a050a0 (calloc)
--26414-- Reading syms from /lib64/libnss_files-2.9.so (0x5492000)
--26414-- REDIR: 0x342ec86df0 (rawmemchr) redirected to 0x4a088e0 (rawmemchr)
--26414-- Discarding syms at 0x5492000-0x569F000 in /lib64/libnss_files-2.9.so due to munmap()
==26414==
==26414== ERROR SUMMARY: 0 errors from 0 contexts (suppressed: 5 from 1)
--26414--
--26414-- supp: 5 dl-hack3-1
==26414== malloc/free: in use at exit: 8,177 bytes in 81 blocks.
==26414== malloc/free: 197 allocs, 116 frees, 29,996 bytes allocated.
==26414==
==26414== searching for pointers to 81 not-freed blocks.
==26414== checked 127,720 bytes.
==26414==
==26414== 168 bytes in 1 blocks are still reachable in loss record 1 of 5
==26414== at 0x4A074D1: realloc (vg_replace_malloc.c:429)
==26414== by 0x4C1C7B6: G__realloc (in /home/metzm/src/grass64_release/dist.x86_64-unknown-linux-gnu/lib/libgrass_gis.6.4.0svn.so)
==26414== by 0x4C28B1B: set_env (in /home/metzm/src/grass64_release/dist.x86_64-unknown-linux-gnu/lib/libgrass_gis.6.4.0svn.so)
==26414== by 0x4C28D27: read_env (in /home/metzm/src/grass64_release/dist.x86_64-unknown-linux-gnu/lib/libgrass_gis.6.4.0svn.so)
==26414== by 0x4C290E6: G__getenv (in /home/metzm/src/grass64_release/dist.x86_64-unknown-linux-gnu/lib/libgrass_gis.6.4.0svn.so)
==26414== by 0x4C29168: G_getenv (in /home/metzm/src/grass64_release/dist.x86_64-unknown-linux-gnu/lib/libgrass_gis.6.4.0svn.so)
==26414== by 0x4C34337: G__location_path (in /home/metzm/src/grass64_release/dist.x86_64-unknown-linux-gnu/lib/libgrass_gis.6.4.0svn.so)
==26414== by 0x4C343A5: G_location_path (in /home/metzm/src/grass64_release/dist.x86_64-unknown-linux-gnu/lib/libgrass_gis.6.4.0svn.so)
==26414== by 0x4C309AB: G__gisinit (in /home/metzm/src/grass64_release/dist.x86_64-unknown-linux-gnu/lib/libgrass_gis.6.4.0svn.so)
==26414== by 0x400E36: main (in /home/metzm/src/grass64_release/dist.x86_64-unknown-linux-gnu/bin/r.watershed)
==26414==
==26414== 353 bytes in 5 blocks are definitely lost in loss record 2 of 5
==26414== at 0x4A0739E: malloc (vg_replace_malloc.c:207)
==26414== by 0x4C1C81E: G__malloc (in /home/metzm/src/grass64_release/dist.x86_64-unknown-linux-gnu/lib/libgrass_gis.6.4.0svn.so)
==26414== by 0x4C3436B: G__location_path (in /home/metzm/src/grass64_release/dist.x86_64-unknown-linux-gnu/lib/libgrass_gis.6.4.0svn.so)
==26414==
==26414== 1,024 bytes in 1 blocks are still reachable in loss record 3 of 5
==26414== at 0x4A05174: calloc (vg_replace_malloc.c:397)
==26414== by 0x4C1C891: G__calloc (in /home/metzm/src/grass64_release/dist.x86_64-unknown-linux-gnu/lib/libgrass_gis.6.4.0svn.so)
==26414== by 0x4C39081: G_recreate_command (in /home/metzm/src/grass64_release/dist.x86_64-unknown-linux-gnu/lib/libgrass_gis.6.4.0svn.so)
==26414== by 0x4C31625: G_command_history (in /home/metzm/src/grass64_release/dist.x86_64-unknown-linux-gnu/lib/libgrass_gis.6.4.0svn.so)
==26414== by 0x400DCD: write_hist (in /home/metzm/src/grass64_release/dist.x86_64-unknown-linux-gnu/bin/r.watershed)
==26414== by 0x4022F0: main (in /home/metzm/src/grass64_release/dist.x86_64-unknown-linux-gnu/bin/r.watershed)
==26414==
==26414== 3,072 bytes in 3 blocks are definitely lost in loss record 4 of 5
==26414== by 0x402272: main (in /home/metzm/src/grass64_release/dist.x86_64-unknown-linux-gnu/bin/r.watershed)
==26414==
==26414== 3,560 bytes in 71 blocks are still reachable in loss record 5 of 5
==26414== by 0x4C4AE9A: G_store (in /home/metzm/src/grass64_release/dist.x86_64-unknown-linux-gnu/lib/libgrass_gis.6.4.0svn.so)
==26414== by 0x4C413B6: G_set_program_name (in /home/metzm/src/grass64_release/dist.x86_64-unknown-linux-gnu/lib/libgrass_gis.6.4.0svn.so)
==26414== by 0x4C3098F: G__gisinit (in /home/metzm/src/grass64_release/dist.x86_64-unknown-linux-gnu/lib/libgrass_gis.6.4.0svn.so)
==26414==
==26414== LEAK SUMMARY:
==26414== definitely lost: 3,425 bytes in 8 blocks.
==26414== possibly lost: 0 bytes in 0 blocks.
==26414== still reachable: 4,752 bytes in 73 blocks.
==26414== suppressed: 0 bytes in 0 blocks.
--26414-- memcheck: sanity checks: 1 cheap, 2 expensive
--26414-- memcheck: auxmaps: 168 auxmap entries (10752k, 10M) in use
--26414-- memcheck: auxmaps_L1: 7886 searches, 54704 cmps, ratio 69:10
--26414-- memcheck: auxmaps_L2: 205 searches, 168 nodes
--26414-- memcheck: SMs: n_issued = 25 (400k, 0M)
--26414-- memcheck: SMs: n_deissued = 1 (16k, 0M)
--26414-- memcheck: SMs: max_noaccess = 524287 (8388592k, 8191M)
--26414-- memcheck: SMs: max_undefined = 0 (0k, 0M)
--26414-- memcheck: SMs: max_defined = 322 (5152k, 5M)
--26414-- memcheck: SMs: max_non_DSM = 24 (384k, 0M)
--26414-- memcheck: max sec V bit nodes: 2 (0k, 0M)
--26414-- memcheck: set_sec_vbits8 calls: 3 (new: 2, updates: 1)
--26414-- memcheck: max shadow mem size: 4528k, 4M
--26414-- translate: fast SP updates identified: 2,975 ( 86.8%)
--26414-- translate: generic_known SP updates identified: 318 ( 9.2%)
--26414-- translate: generic_unknown SP updates identified: 133 ( 3.8%)
--26414-- tt/tc: 8,885 tt lookups requiring 9,154 probes
--26414-- tt/tc: 8,885 fast-cache updates, 6 flushes
--26414-- transtab: new 4,048 (89,632 -> 1,492,661; ratio 166:10) [0 scs]
--26414-- transtab: dumped 0 (0 -> ??)
--26414-- transtab: discarded 70 (1,294 -> ??)
--26414-- scheduler: 154,625 jumps (bb entries).
--26414-- scheduler: 1/5,524 major/minor sched events.
--26414-- sanity: 2 cheap, 2 expensive checks.
--26414-- exectx: 769 lists, 207 contexts (avg 0 per list)
--26414-- exectx: 318 searches, 135 full compares (424 per 1000)
--26414-- exectx: 140 cmp2, 10 cmp4, 0 cmpAll
--26414-- errormgr: 10 supplist searches, 145 comparisons during search
--26414-- errormgr: 5 errlist searches, 10 comparisons during search
SEG mode:
CMD="r.watershed elevation=elevation@PERMANENT threshold=3000 accumulation=elevation.acc drainage=elevation.dir basin=elevation.basin stream=elevation.stream -m --overwrite"
==26557== Memcheck, a memory error detector.
==26557== Copyright (C) 2002-2007, and GNU GPL'd, by Julian Seward et al.
==26557== Using LibVEX rev 1804, a library for dynamic binary translation.
==26557== Copyright (C) 2004-2007, and GNU GPL'd, by OpenWorks LLP.
==26557== Using valgrind-3.3.0, a dynamic binary instrumentation framework.
==26557== Copyright (C) 2000-2007, and GNU GPL'd, by Julian Seward et al.
==26557==
--26557-- Command line
--26557-- r.watershed
--26557-- elevation=elevation@PERMANENT
--26557-- threshold=3000
--26557-- accumulation=elevation.acc
--26557-- drainage=elevation.dir
--26557-- basin=elevation.basin
--26557-- stream=elevation.stream
--26557-- -m
--26557-- --overwrite
--26557-- Startup, with flags:
--26557-- -v
--26557-- --tool=memcheck
--26557-- --leak-check=yes
--26557-- --show-reachable=yes
--26557-- Contents of /proc/version:
--26557-- Linux version 2.6.27.15-c0.1 (mkkas@monster) (gcc version 4.3.2 20081105 (Red Hat 4.3.2-7) (GCC) ) #1 SMP Tue Feb 24 11:46:22 CET 2009
--26557-- Arch and hwcaps: AMD64, amd64-sse2
--26557-- Page sizes: currently 4096, max supported 4096
--26557-- Valgrind library directory: /usr/lib64/valgrind
--26557-- Reading syms from /home/metzm/src/grass64_release/dist.x86_64-unknown-linux-gnu/bin/r.watershed (0x400000)
--26557-- Reading syms from /usr/lib64/valgrind/amd64-linux/memcheck (0x38000000)
--26557-- object doesn't have a dynamic symbol table
--26557-- Reading syms from /lib64/ld-2.9.so (0x342D800000)
--26557-- Reading suppressions file: /usr/lib64/valgrind/default.supp
--26557-- Reading syms from /usr/lib64/valgrind/amd64-linux/vgpreload_core.so (0x4802000)
--26557-- Reading syms from /usr/lib64/valgrind/amd64-linux/vgpreload_memcheck.so (0x4A03000)
--26557-- REDIR: 0x342d817d30 (index) redirected to 0x4a07890 (index)
--26557-- REDIR: 0x342d817ee0 (strcmp) redirected to 0x4a07e50 (strcmp)
--26557-- REDIR: 0x342d817ff0 (strlen) redirected to 0x4a07b50 (strlen)
--26557-- Reading syms from /home/metzm/src/grass64_release/dist.x86_64-unknown-linux-gnu/lib/libgrass_gis.6.4.0svn.so (0x4C0B000)
--26557-- Reading syms from /home/metzm/src/grass64_release/dist.x86_64-unknown-linux-gnu/lib/libgrass_datetime.6.4.0svn.so (0x4E67000)
--26557-- Reading syms from /lib64/libz.so.1.2.3 (0x342FC00000)
--26557-- object doesn't have a symbol table
--26557-- Reading syms from /lib64/libm-2.9.so (0x342F000000)
--26557-- Reading syms from /lib64/libc-2.9.so (0x342EC00000)
--26557-- Reading syms from /lib64/libdl-2.9.so (0x342F400000)
--26557-- REDIR: 0x342ec81310 (rindex) redirected to 0x4a076f0 (rindex)
--26557-- REDIR: 0x342ec80e40 (strlen) redirected to 0x4a07b10 (strlen)
--26557-- REDIR: 0x342ec7c9a0 (malloc) redirected to 0x4a072d0 (malloc)
--26557-- REDIR: 0x342ec808f0 (strcpy) redirected to 0x4a07b70 (strcpy)
--26557-- REDIR: 0x342ec7a410 (free) redirected to 0x4a05fd0 (free)
--26557-- REDIR: 0x342ec810e0 (strncmp) redirected to 0x4a07d70 (strncmp)
--26557-- REDIR: 0x342ec808b0 (strcmp) redirected to 0x4a07df0 (strcmp)
--26557-- REDIR: 0x342ec7ce90 (realloc) redirected to 0x4a073f0 (realloc)
--26557-- REDIR: 0x342ec86f10 (strchrnul) redirected to 0x4a088a0 (strchrnul)
--26557-- REDIR: 0x342ec83890 (mempcpy) redirected to 0x4a08900 (mempcpy)
--26557-- REDIR: 0x342ec82d60 (memset) redirected to 0x4a087d0 (memset)
--26557-- REDIR: 0x342ec80700 (index) redirected to 0x4a07810 (index)
--26557-- REDIR: 0x342ec841d0 (memcpy) redirected to 0x4a07f60 (memcpy)
--26557-- REDIR: 0x342ec35d50 (putenv) redirected to 0x4a08ac0 (putenv)
--26557-- REDIR: 0x342ec80f30 (strnlen) redirected to 0x4a07ac0 (strnlen)
--26557-- REDIR: 0x342ec80540 (strcat) redirected to 0x4a078d0 (strcat)
SECTION 1 beginning: Initiating Variables. 5 sections total.
100%
100%
100%
100%
100%
--26557-- REDIR: 0x342ec82500 (memchr) redirected to 0x4a07f10 (memchr)
--26557-- REDIR: 0xffffffffff600400 (???) redirected to 0x3802d09d (vgPlain_amd64_linux_REDIR_FOR_vtime)
--26557-- REDIR: 0x342ec811b0 (strncpy) redirected to 0x4a07c40 (strncpy)
--26557-- REDIR: 0x342ec83ea0 (stpcpy) redirected to 0x4a08560 (stpcpy)
--26557-- REDIR: 0x342ec7c600 (calloc) redirected to 0x4a050a0 (calloc)
--26557-- Reading syms from /lib64/libnss_files-2.9.so (0x5492000)
--26557-- REDIR: 0x342ec86df0 (rawmemchr) redirected to 0x4a088e0 (rawmemchr)
--26557-- Discarding syms at 0x5492000-0x569F000 in /lib64/libnss_files-2.9.so due to munmap()
==26557==
==26557== ERROR SUMMARY: 0 errors from 0 contexts (suppressed: 5 from 1)
--26557--
--26557-- supp: 5 dl-hack3-1
==26557== malloc/free: in use at exit: 8,177 bytes in 81 blocks.
==26557== malloc/free: 197 allocs, 116 frees, 29,996 bytes allocated.
==26557==
==26557== searching for pointers to 81 not-freed blocks.
==26557== checked 127,744 bytes.
==26557==
==26557== 168 bytes in 1 blocks are still reachable in loss record 1 of 5
==26557== at 0x4A074D1: realloc (vg_replace_malloc.c:429)
==26557== by 0x4C1C7B6: G__realloc (in /home/metzm/src/grass64_release/dist.x86_64-unknown-linux-gnu/lib/libgrass_gis.6.4.0svn.so)
==26557== by 0x4C28B1B: set_env (in /home/metzm/src/grass64_release/dist.x86_64-unknown-linux-gnu/lib/libgrass_gis.6.4.0svn.so)
==26557== by 0x4C28D27: read_env (in /home/metzm/src/grass64_release/dist.x86_64-unknown-linux-gnu/lib/libgrass_gis.6.4.0svn.so)
==26557== by 0x4C290E6: G__getenv (in /home/metzm/src/grass64_release/dist.x86_64-unknown-linux-gnu/lib/libgrass_gis.6.4.0svn.so)
==26557== by 0x4C29168: G_getenv (in /home/metzm/src/grass64_release/dist.x86_64-unknown-linux-gnu/lib/libgrass_gis.6.4.0svn.so)
==26557== by 0x4C34337: G__location_path (in /home/metzm/src/grass64_release/dist.x86_64-unknown-linux-gnu/lib/libgrass_gis.6.4.0svn.so)
==26557== by 0x4C343A5: G_location_path (in /home/metzm/src/grass64_release/dist.x86_64-unknown-linux-gnu/lib/libgrass_gis.6.4.0svn.so)
==26557== by 0x4C309AB: G__gisinit (in /home/metzm/src/grass64_release/dist.x86_64-unknown-linux-gnu/lib/libgrass_gis.6.4.0svn.so)
==26557== by 0x400E36: main (in /home/metzm/src/grass64_release/dist.x86_64-unknown-linux-gnu/bin/r.watershed)
==26557==
==26557== 353 bytes in 5 blocks are definitely lost in loss record 2 of 5
==26557== at 0x4A0739E: malloc (vg_replace_malloc.c:207)
==26557== by 0x4C1C81E: G__malloc (in /home/metzm/src/grass64_release/dist.x86_64-unknown-linux-gnu/lib/libgrass_gis.6.4.0svn.so)
==26557== by 0x4C3436B: G__location_path (in /home/metzm/src/grass64_release/dist.x86_64-unknown-linux-gnu/lib/libgrass_gis.6.4.0svn.so)
==26557==
==26557== 1,024 bytes in 1 blocks are still reachable in loss record 3 of 5
==26557== at 0x4A05174: calloc (vg_replace_malloc.c:397)
==26557== by 0x4C1C891: G__calloc (in /home/metzm/src/grass64_release/dist.x86_64-unknown-linux-gnu/lib/libgrass_gis.6.4.0svn.so)
==26557== by 0x4C39081: G_recreate_command (in /home/metzm/src/grass64_release/dist.x86_64-unknown-linux-gnu/lib/libgrass_gis.6.4.0svn.so)
==26557== by 0x4C31625: G_command_history (in /home/metzm/src/grass64_release/dist.x86_64-unknown-linux-gnu/lib/libgrass_gis.6.4.0svn.so)
==26557== by 0x400DCD: write_hist (in /home/metzm/src/grass64_release/dist.x86_64-unknown-linux-gnu/bin/r.watershed)
==26557== by 0x4022F0: main (in /home/metzm/src/grass64_release/dist.x86_64-unknown-linux-gnu/bin/r.watershed)
==26557==
==26557== 3,072 bytes in 3 blocks are definitely lost in loss record 4 of 5
==26557== by 0x402272: main (in /home/metzm/src/grass64_release/dist.x86_64-unknown-linux-gnu/bin/r.watershed)
==26557==
==26557== 3,560 bytes in 71 blocks are still reachable in loss record 5 of 5
==26557== by 0x4C4AE9A: G_store (in /home/metzm/src/grass64_release/dist.x86_64-unknown-linux-gnu/lib/libgrass_gis.6.4.0svn.so)
==26557== by 0x4C413B6: G_set_program_name (in /home/metzm/src/grass64_release/dist.x86_64-unknown-linux-gnu/lib/libgrass_gis.6.4.0svn.so)
==26557== by 0x4C3098F: G__gisinit (in /home/metzm/src/grass64_release/dist.x86_64-unknown-linux-gnu/lib/libgrass_gis.6.4.0svn.so)
==26557==
==26557== LEAK SUMMARY:
==26557== definitely lost: 3,425 bytes in 8 blocks.
==26557== possibly lost: 0 bytes in 0 blocks.
==26557== still reachable: 4,752 bytes in 73 blocks.
==26557== suppressed: 0 bytes in 0 blocks.
--26557-- memcheck: sanity checks: 1 cheap, 2 expensive
--26557-- memcheck: auxmaps: 168 auxmap entries (10752k, 10M) in use
--26557-- memcheck: auxmaps_L1: 7886 searches, 54704 cmps, ratio 69:10
--26557-- memcheck: auxmaps_L2: 205 searches, 168 nodes
--26557-- memcheck: SMs: n_issued = 25 (400k, 0M)
--26557-- memcheck: SMs: n_deissued = 1 (16k, 0M)
--26557-- memcheck: SMs: max_noaccess = 524287 (8388592k, 8191M)
--26557-- memcheck: SMs: max_undefined = 0 (0k, 0M)
--26557-- memcheck: SMs: max_defined = 322 (5152k, 5M)
--26557-- memcheck: SMs: max_non_DSM = 24 (384k, 0M)
--26557-- memcheck: max sec V bit nodes: 2 (0k, 0M)
--26557-- memcheck: set_sec_vbits8 calls: 3 (new: 2, updates: 1)
--26557-- memcheck: max shadow mem size: 4528k, 4M
--26557-- translate: fast SP updates identified: 2,977 ( 86.8%)
--26557-- translate: generic_known SP updates identified: 318 ( 9.2%)
--26557-- translate: generic_unknown SP updates identified: 133 ( 3.8%)
--26557-- tt/tc: 8,936 tt lookups requiring 9,209 probes
--26557-- tt/tc: 8,936 fast-cache updates, 6 flushes
--26557-- transtab: new 4,072 (90,214 -> 1,509,917; ratio 167:10) [0 scs]
--26557-- transtab: dumped 0 (0 -> ??)
--26557-- transtab: discarded 70 (1,294 -> ??)
--26557-- scheduler: 154,870 jumps (bb entries).
--26557-- scheduler: 1/5,551 major/minor sched events.
--26557-- sanity: 2 cheap, 2 expensive checks.
--26557-- exectx: 769 lists, 207 contexts (avg 0 per list)
--26557-- exectx: 318 searches, 135 full compares (424 per 1000)
--26557-- exectx: 140 cmp2, 10 cmp4, 0 cmpAll
--26557-- errormgr: 10 supplist searches, 145 comparisons during search
--26557-- errormgr: 5 errlist searches, 10 comparisons during search
I can't see anything to worry about, should valgrind be run with other options?
Markus M
