On Thu, 17 Aug 2006, Dylan Beaudette wrote:
On Thursday 17 August 2006 06:41, Maciej Sieczka wrote:
Hans Hauska napisa?(a):
SECTION 5: Closing Maps.
everything seems to work fine, but When it reaches Section 5 then it
just stands on one point and chews ....
I had it run for over 12 hours, but nothing happened in the final stage
and it never finished.
Has anyone been able to successfully run it?
Is there a special trick? Should I use a Linux version (that is possible)
I'd appreciate any hints or suggestions on the matter.This is a long-standing bug http://intevation.de/rt/webrt?serial_num=3112
r.watershed completes fine on smaller input. On bigger it hangs (don't
know what the exact threshold is though).Maciek
Helena recently commented on this:
r.terraflow currently has only multiple flow directions option which
should give better results for hillslope erosion. On floodplains it
spreads water
so it won't create a single cell wide stream. It will be worth trying
to see how the results look like
with r.usped. Note that it is faster only on massive grids - for
regular sized grids
(1000x1000) it may be the same as r.watershed.
For stream extraction with depressions r.watershed gives more
accurate results
but it gets stuck for grids larger than approx 1500x1500 (depending
how big your memory is).
r.terraflow runs on 10,000x10,000 with no problems. Duke univ. team
is working on new version,
but I did not have a chance to try it yet and it has not been yet
implemented in GRASS.
Ultimately my plan was to replace all flow routing with r.terraflow
but it looks like
that won't be possible because some of the algorithms cannot be
rewritten as I/O efficient,
so we will keep r.watershed for now.I cc this to Dylan - regarding the r.watershed getting stuck on step
5, it may be just color table
(it assigns a random color to each subwatershed and that search for
colors gets stuck when
there are too many-
if somebody would be willing to look at it (modify the code and test it)
I will be happy to help. Hamish identified the problem long time ago
(I might have submitted a bug report)
but I don't have enough time to explore it (I looked at the code, it
may not be too complicated).
Yes it seems quite simple. It assigns a random colour table with G_make_random_colors(), which is fast even for a huge number of watersheds, but then there is some extra code which appears to "prettify" the colour table in some way. It is really inefficient for large numbers of watersheds. Totally disabling it and just using the random colour table results in the program completing quickly even for a ridiculously huge number of watersheds, but I guess seeing it appears to prettify the output it would be worth keeping it in for number of watersheds below some arbitrary threshold?
Maybe Helena remembers what exactly the prettifying achieves or what problem it overcomes?
The files with the inefficient routine appear to be:
raster/r.watershed/ram/close_maps2.c
raster/r.watershed/seg/close_maps2.c
raster/r.watershed/shed/close_maps2.c
and here is an example from ram/close_maps2.c:
r = 1;
incr = 0;
while(incr >= 0) {
for (gr=130+incr; gr<=255; gr += 20) {
for (rd=90+incr; rd<=255; rd += 30) {
for (bl=90+incr; bl<=255; bl += 40) {
flag = 1;
while (flag) {
G_get_color(r,&red,&green,&blue, &colors);
if((blue*.11 + red*.30 + green*.59) < 100) {
G_set_color(r, rd, gr, bl, &colors);
flag = 0;
if (++r > max) {
gr = rd = bl = 300;
flag = 0;
incr = -1;
if (incr >= 0) {
incr += 15;
if (incr > 120)
incr = 7;
When r.watershed gets stuck on step 2, that is when it cannot be done/
fixed.
I just looked at Hans' command and if he used threshold 75 with a DEM
that is around 1000x1000,
that is where his problem is - he should use much larger threshold
(thousands at least).Helena
So it would seem that we need to find a better random color generator to
r.watershed, or just disable the color table if num watersheds > some
threshold. I'll poke around in the source later today.Dylan
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341_______________________________________________
grassuser mailing list
grassuser@grass.itc.it
