[GRASS-dev] Re: [GRASS-user] Re: Importing of raster data doesn't seem to work through GUI
On 06/12/2010 13:37, Chethan S. wrote:
Unfortunately, that does not work for me. As you said the *.tif files appear
grayed out in that particular folder. But the next outcome is not the one
you get. Also after a recent update of GRASS 6.4.1 SVN there is no option
"Bulk Import of Raster data". Its only "import raster data". I select
directory option there. For using the individual file import option like
before I used "Command Dialog" option as shown below. I should also mention
that I use GRASS 6.4.0 version from Ubuntu repository at my college but
again face the same problem.
http://osgeo-org.1803224.n2.nabble.com/file/n5807453/Selection_022.png
Chethan S.
I think I have an idea why the GUI isn't working. I noticed in your first post that the LandSAT tif files are named with CAPS in the filename extension, i.e. 171146051_05122001402_B10.TIF. It looks to me that the GUI ignores files name *.TIF and only "sees" *.tif.
You can do a bulk rename of all the files (from the command line...) with
for f in *.TIF; do mv $f `basename $f .TIF`.tif; done
Then open the GUI and check if those files are added to the import list.
Micha
Micha Silver
http://www.surfaces.co.il/
Arava Development Co. +972-52-3665918
2010/12/6 Micha Silver <micha@arava.co.il>:
this bug hopefully fixed by r44554.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
On 12/07/2010 04:08 PM, Martin Landa wrote:
2010/12/6 Micha Silver<micha@arava.co.il>:
Great. Thanks, Martin.
Martin
Micha Silver
Sir,
That was a brilliant observation from your side. Now the feature works. In fact that is how the landsat data files are named, with *.TIF extension. Anyway I can save lot of time now.
Thanks and Regards,
Chethan S.
“Bulk Import of Raster data”. Its only “import raster data”. I select
before I used “Command Dialog” option as shown below. I should also mention
Chethan S.
I think I have an idea why the GUI isn’t working. I noticed in your first post that the LandSAT tif files are named with CAPS in the filename extension, i.e. 171146051_05122001402_B10.TIF. It looks to me that the GUI ignores files name *.TIF and only “sees” *.tif.
You can do a bulk rename of all the files (from the command line…) with
for f in *.TIF; do mv $f basename $f .TIF.tif; done
Micha
Micha Silver
Chethan S.
