Martin wrote:
in GRASS 7 we can support as key column also non-integer
columns,
"just because we can, doesn't mean we should" ...
Hamish
columns,
Hamish
ps- if cleaning up NC data please fix UID.GID in tarball and
remove cruft from mapset dirs (.tmp, etc.)
thanks
Hamish
2009/10/18 Hamish <hamish_b@yahoo.com>:
columns,"just because we can, doesn't mean we should" ...
why key column should be restricted only for integers? If you use
unique strings as keys I don't see any problem (just indexing is
slower).
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
2009/10/18 Martin Landa <landa.martin@gmail.com>:
slower).
or better to say if db driver supports creating index on non-integer
column why to restrict it on GRASS level?
Martin
Hamish wrote:
columns,
+1
The key column is used to link attributes to vector features through the category number assigned to vector features. Category numbers are stored both in the coor and in the cidx file as integer, changing that would break forward/backward compatibility completely. Unless there are huge advantages of cat values being double instead of integer, I would suggest not to rewrite substantial parts of the vector libs and many vector modules in order to support cat values as double (or char* or whatever).
Markus M
If this is a change request please tell us what the problem is
- .tmp - I see some spurious 0 byte entries which should be removed.
- but UID.GID?
I can do an update of the data set to the extent that it does not break
any instruction material (adding metadata is one of items
on my TODO list) so let me know any other things that need fixing.
I have an additional mapset for this location with time series of
coastal lidar data which I can post if it would be useful
(great for showing what you can do with r.series)
I too have no idea what UID.GIS is,
Helena
remove cruft from mapset dirs (.tmp, etc.)If this is a change request please tell us what the problem is
- but UID.GID?Markus
grass-dev mailing list
grass-dev@lists.osgeo.org
2009/10/23 Helena Mitasova <hmitaso@unity.ncsu.edu>:
+1
Martin
