An update:
Thanks to Glynn Clements, switching from 64 to 65 solved all my problems and now my python script works fine on win XP too giving the command:
python “complete_path_to_the_script”+options
from the command line of the layer manager.
Otherwise I was unable to use the 70 GRASS version because of a strange error at the end of the installation process:
I attach an image of my desktop… maybe this is useful for devs.
http://img299.imageshack.us/img299/484/imagewx.png
Yours, Annalisa
2010/5/12 Annalisa Minelli <annagrass6@gmail.com>
Many thanks Daniel,
I gave a look at that thread few days ago but I didn’t found an answer… maybe because I would like (if it’s possible) not to build grass on windows and I supposed the 6.4 version was more “stable” than 7.
But when I found that a similar problem on linux (and I know for sure problems on linux can be solved…) I had a hope to solve the same on win too.However, many thanks for the hints.
I’ll update you if I obtain something good.Yours, Annalisa.
2010/5/12 LeeDaniel <Lee.Daniel.1986@gmail.com>
Hey there,
Sorry I don’t have an answer, but maybe it contributes to the understanding
of the problem:I’ve also had this exact same error message when trying to run my own python
scripts from shell under Windows. The scripts seem to be fine, but GRASS was
unable to use them. Somebody posted what I believe might be a solution, if
the problem’s python-based, but I haven’t tried it because I rewrote it as a
shell script using Linux.Here’s the thread:
http://osgeo-org.1803224.n2.nabble.com/Problem-with-running-Python-script-in-GRASS-td5007296.html#a5007296-Daniel
View this message in context: http://osgeo-org.1803224.n2.nabble.com/r-lake-starting-from-shell-problem-tp5035268p5040119.html
grass-user mailing list
grass-user@lists.osgeo.org
