[GRASS-dev] Re: [GRASS-user] scientific notation
Fwd from Ivan, I wonder how G_scan_easting() and G_scan_northing() fit into
this problem? (for 1.2345e6 not 123:45:54.321E; 31E needs to be considered
East)
--Hamish
Note: forwarded message attached.
      ____________________________________________________________________________________
Be a better sports nut! Let your teams follow you
with Yahoo Mobile. Try it now. http://mobile.yahoo.com/sports;_ylt=At9_qDKvtAbMuh1G1SQtBI7ntAcJ
2007/11/25, Hamish <hamish_nospam@yahoo.com>:
I do not fully understand this notation
East)
anyway
$ cat pok.txt
123:45:54.321E|80N
1.2376508917e2|80N
$ v.in.ascii in=pok.txt out=pok
$ v.out.ascii pok
123.76508917|80|1
123.76508917|80|2
works for me...
Martin
--Hamish
---------- Messaggio inoltrato ----------
To: Hamish <hamish_nospam@yahoo.com>
Date: Sun, 25 Nov 2007 15:36:50 +0600
Subject: Re: [GRASS-user] scientific notation
>> Can GRASS actualy deal with number written with scientific notation ?
>> Is there a specific way to deal with these numbers ?
> v.in.ascii coulumn scanning code seems to overlook that case.
        Since my message has apparently not reached grass-dev, and since
        you're interested in this problem, I'm forwarding it to you.
        The problem seems to me somewhat trivial to solve.
To: Martin Landa <landa.martin@gmail.com>
Date: Sat, 24 Nov 2007 22:35:48 +0600
Subject: Re: scientific notation
>>>>> Martin Landa <landa.martin@gmail.com> writes:
>> I would like to import points data in GRASS (with v.in.ascii). My
>> data includes number written with the scientific notation (for
>> example 1.2e+23). During the import, I am defining them as double.
>> Unfortunately, it doesn't work...
>> I get the following message :
>> " ERROR: Column 9 defined as double has string values "
> no, it seems, v.in.ascii doesn't support it...
        It seems that it's the is_double () function which behaves in a
        wrong way:
$ nl -ba grass-6.3.cvs_src_snapshot_2007_11_03/vector/v.in.ascii/points.c
    30 /* Determine if the string is double, e.g. 123.456, +123.456, -123.456
    31 * return 1 if double, 0 otherwise */
    32 static int is_double(char *str)
    33 {
    34 int i = -1, ndots = 0;
    35
    36 while (str[++i] != '\0') {
    37 if (i == 0 && (str[i] == '+' || str[i] == '-'))
    38 continue;
    39
    40 if (str[i] == '.') {
    41 if (ndots > 0)
    42 return 0; /* > 1 dot */
    43
    44 ndots++;
    45 continue;
    46 }
    47
    48 if (!isdigit(str[i]))
    49 return 0;
    50 }
    51
    52 return 1;
    53 }
        IIUC, the number is to be converted from its string
        representation by atof () later. Since, I assume, atof ()
        supports e-notation, there's no necessity in such a strict check
        like is_double () currently performs. Therefore, I suggest
        is_double () to be reimplemented on top of strtod () instead,
        e. g.:
static int
is_double (char *s)
  char *tail;
  if (strtod (s, &tail),
      tail == s || *tail != '\0') {
    /* doesn't look like a number,
       or has extra characters after what looks to be a number */
    return 0;
  return 1;
        BTW, is_int () could be rewritten as well.
grass-dev mailing list
grass-dev@lists.osgeo.org
Martin Landa <landa.martin@gmail.com> * http://gama.fsv.cvut.cz/~landa *
re. yesterday's v.in.ascii changes, rev 1.51
  http://freegis.org/cgi-bin/viewcvs.cgi/grass6/vector/v.in.ascii/in.c
"Changes since 1.50: +465 -425 lines
Run indent
Message standardization"
Please do not mix code changes with indent changes!
It makes it very hard to review the code changes.
SUBMITTING rule 15:
    Existing code should not be re-indented except in extreme cases, as this
    will make "diff" comparisons with older versions impossible. If indent is
    needed, do not check in any changes other than the indentation in the same
    commit! Do add the indent switches and any indent warning messages to the
    CVS log. Any change or fix mixed in with an indent is very hard to track
    making it hard for others to follow the change or fix any new bugs.
and changing the v.in.ascii columns= option to use
G_define_standard_option(G_OPT_COLUMNS) is not very safe as the standard option
is really meant for a different column= task. If in future someone changed the
parser.c definition for the intended task, v.in.ascii's option could change in
an undesirable way.
note that by doing that you have changed the name of the option in an
incompatible way-
v.in.ascii was:
    columns_opt->key = "columns";
while parser.c sets it to
        case G_OPT_COLUMNS:
            Opt->key = "column";
Anyone who scripted "columns=" will now get an error.
(regardless of above, perhaps it would be a good idea to change G_OPT_COLUMNS
to key->"columns" in parser.c? the change would be backwards compatible as the
options work on minimum letter match)
thanks,
Hamish
Get easy, one-click access to your favorites.
Make Yahoo! your homepage.
http://www.yahoo.com/r/hs
Hamish,
2007/11/26, Hamish <hamish_nospam@yahoo.com>:
Run indent
SUBMITTING rule 15:
well, sorry.
an undesirable way.
incompatible way-
v.in.ascii was:
        case G_OPT_COLUMNS:
already done
http://freegis.org/cgi-bin/viewcvs.cgi/grass6/lib/gis/parser.c.diff?r1=1.133&r2=1.134
Martin
thanks,
Hamish
Hamish
Martin wrote:
Hamish,
well, sorry.
just a friendly reminder to everyone :slight_smile:
Hamish
