Forwarding this to grass-dev as I think there are more people here that might be able to help:
-------- Forwarded Message --------
Subject: Re: [GRASS-user] script html manual file directory
Date: Wed, 2 May 2018 23:51:21 +0200
Organization: Geophom
To: Moritz Lennert <mlennert@club.worldonline.be>
CC: grass-user@lists.osgeo.org
Thank you for your advices Moritz !
I succeed (I guess..) to make a package with several python scripts (one by sub-folder) and a shared library (in its own sub-folder). I can install with g.extension (only in command line) (why?). But the entries does not appear in g.extension list because they are not in in .grass7/addons/modules.xml. I do not find anything about the way to add my entries in that file. It's not a part of Makefile commands. How it's handled ?
I notice that: if I install twice my package (suite) with g.extension, the library sub-folder is copied inside the library sub-folder (one level too low and do not replace), if I install once again, the library replace the lowest level folder. So, If i update the library I must remove manually the library to keep it at the right level. Do you have an idea of the reason ? (I suppose Makefile, but I don't understand - see below the Makefile)
I have created a custom menu toolboxes.xml. Is there a way ton install my menu and insert the sub-toolbox in main_menu.xml ?
Concerning french accent, as you suggest, I can use html special characters &xxx; for the <description> part, and it works. But not in the #% description module entries of the python script for correct display in gui. However, the manual display bad characters in the upper section (like é for é), and good in the lowest... Is there a way to have accent both in gui and manual ?
Frank
_Library Makefile:_
MODULE_TOPDIR = ../../..
include $(MODULE_TOPDIR)/include/Make/Other.make
include $(MODULE_TOPDIR)/include/Make/Python.make
MODULES = utils __init__
PGM = r.wtg
LIBDIR = libwtg
ETCDIR = $(ETC)/$(PGM)/$(LIBDIR)
PYFILES := $(patsubst %,$(ETCDIR)/%.py,$(MODULES))
PYCFILES := $(patsubst %,$(ETCDIR)/%.pyc,$(MODULES))
default: $(PYFILES) $(PYCFILES)
$(ETCDIR):
$(MKDIR) $@
$(ETCDIR)/%: % | $(ETCDIR)
$(INSTALL_DATA) $< $@
install:
$(MKDIR) $(INST_DIR)/etc/$(PGM)
cp -r $(ETCDIR) $(INST_DIR)/etc/$(PGM)/$(LIBDIR)
Le 27/04/2018 à 17:34, Moritz Lennert a écrit :
Le Fri, 27 Apr 2018 16:08:00 +0200,
Frank David<frank.david@geophom.fr> a écrit :Thank you Moritz,
I succeed to install python script, But.. my script use a custom lib
in a sub-folder for my shared functions, so g.extension fails with
the line "from gg.geolib import *". How may I manage this included
lib ?Check examples of other scripts and how they handle this. For example:
r.agent [1] or r.green [2].Check the Makefiles at each level, including the one in the
library directory, and how the set the path for import of the library
files before importing them:From r.agent.rand [3]:
from grass.pygrass.utils import set_path
set_path('r.agent', 'libagent', '..')
from libagent import error, grassland, worldWithout this include, install works (only on console, not with gui)
You would need to give us more details: what do you do exactly and what
doesn't work ?and allows to exec the script from console. I notice encoding manual
is not in UTF-8. Is it possible to force UTF-8 encoding ?.I don't think so, but others should know better than me. If you want to
include accented characters, you should use html symbol codes (i.e.
'à' for à, etc).However,
my custom menu (toolboxes.xml) fails with the following error :"/usr/local/grass-7.4.0svn/gui/wxpython/lmgr/frame.py", line
905, in OnMenuCmdGUI(parent=self, giface=self._giface).ParseCommand(cmd)
File
"/usr/local/grass-7.4.0svn/gui/wxpython/gui_core/forms.py",
line 2834, in ParseCommandraise gcmd.GException(e.value)
core.gcmd
GException
Unable to fetch interface description for command
'gzvibin.py'.
Details: [Errno 2] No such file or directoryThis sounds like it cannot find gzvibin.py. How and where did you
'install' it ?Moritz
[1]
https://trac.osgeo.org/grass/browser/grass-addons/grass7/raster/r.agent
[2]
https://trac.osgeo.org/grass/browser/grass-addons/grass7/raster/r.green
[3]
https://trac.osgeo.org/grass/browser/grass-addons/grass7/raster/r.agent/r.agent.rand/r.agent.rand.py#L91
