On Jan 24, 2008, at 6:52 AM, grass-user-request@lists.osgeo.org wrote:
Date: Thu, 24 Jan 2008 05:12:03 -0800 (PST)
Subject: [GRASS-user] v.coordinate.sh - improve this script?
To: grass-user@lists.osgeo.org
Message-ID: <15063748.post@talk.nabble.com>
Content-Type: text/plain; charset=us-asciiHi list.
I made a script (attached) for the definition of interactive text file
(containing the coordinates input and output) to be loaded later in
v.transform.It is useful to write automatically coordinates in the text file.
Operation is simple:
- A load map (not georeference) and the map B (which may be raster or
vector) and will open 2 monitor.- We need to move the first monitor to the side of the second monitor.
- Proceed doing a zoom (if necessary) on the first monitor (A map) and then
identifying the input point (GCP) with one click. After this transaction
will be made to locate the point on the second monitor (B map).
The pairs of points are identifying 4 (at least 4). For more points see a
graphic which will require to continue with the process or not.- After the inclusion of the points in your / home will be a text file
'coordinate.txt' formatted for use in v.transform.The script is certainly improved. For example viewing points included (as eg
in i.points on in d.path) or shifting automatically monitors or using snap
for the insertion points etc. ...I have no programming experience, and I hope that someone can help me
improve.Gabriele
PS
Necessary installing xdialog and xmessage
http://www.nabble.com/file/p15063748/v.coordinate.sh v.coordinate.sh
View this message in context: http://www.nabble.com/v.coordinate.sh---improve-this-script--tp15063748p15063748.html
Gabriele,
It is good to learn scripting of some kind because it really expands the analytical capabilities of GRASS. However, I'm not sure why you are trying to create a bash script for interactive georectifying.
i.points already does with with xmonitors. However, this will not work on Windows because it doesn't support the underlying socket code for the monitor drivers.
The TclTk GUI already has a more sophisticated replacement for this function that works on all platforms.
Also, given issues (long known) that we've run into again with running bash scripts on Windows, I think that now is the time to begin to strongly encourage GRASS users and developers to try to begin shifting their scripting to a platform that works on all OS's. Since the new GUI will be in Python, I strongly suggest that we start developing new scripts in Python and for anyone with time on their hands start to create Python versions of existing scripts. The more scripts that are available in Python, the more people will make sure that Python is installed and will take a look at it, which will lead to more scripts in Python, etc...
Already, a Python script can pop up the same TclTk GUI that a bash script can, and has the option of popping up a wxPython GUI if this is installed.
Michael
____________________
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
