[GRASS-dev] Re: [GRASS-user] v.digit cannot update table
Seb wrote:
On Sat, 21 Apr 2007 14:33:50 -0500,
Seb <spluque@gmail.com> wrote:
Hi, In GRASS CVS, I'm encountering problems digitizing into a vector
with the following:
v.digit -n map=newvect bg="d.vect coastline"
Clicking on the settings button -> table tab -> "create table" tells me
that a new empty map has been created. I then proceed with the
"digitize new boundary" button and create a polygon. When
right-clicking to close the line I'm asked about what encoding to use (I
leave it as utf-8 which which is my locale) and then "submit", I receive
the following error:
The cause of this error was that the table needs to have more than the
'cat' column. I was simply creating the table without adding an extra
column because I don't need any attributes.
The problem has been already reported 8 months ago:
http://intevation.de/rt/webrt?serial_num=5127
Maciek
