[GRASS-dev] Re: [GRASS-user] v.in.ascii error message
you need to delimit records with | not lines
and then have one record per line like this:
W115|58|2.4
N36|27|20.9
Also, I am not sure if W115 or N36 is a correct
way of specifying the coordinates?
Unfortunately, v.in.ascii almost always give that
error message, which is usually not to helpful.
Benjamin
gary wrote:
I find this error message from v.in.ascii a bit cryptic.
grass command:
v.in.ascii input=/usr/localsrc/utm/PERMANENT/site.dat output=sites5
format=point fs=| skip=0 x=1 y=2 z=0 cat=0
error message:
Maximum input row length: 24
Maximum number of columns: 2
Minimum number of columns: 0
GRASS_INFO_ERROR(15897,1): x column number > minimum last column number
GRASS_INFO_ERROR(15897,1): (incorrect field separator?)
The file site. dat is one line as follows
W115 58 2.4|N36 27 20.9
The default separator is "pipe", so I'm sure the delimiter is fine. Any idea what I'm doing wrong here?
grassuser mailing list
grassuser@grass.itc.it
Benjamin Ducke, M.A.
Archäoinformatik
(Archaeoinformation Science)
Institut für Ur- und Frühgeschichte
(Inst. of Prehistoric and Historic Archaeology)
Christian-Albrechts-Universität zu Kiel
Johanna-Mestorf-Straße 2-6
D 24098 Kiel
Germany
Tel.: ++49 (0)431 880-3378 / -3379
Fax : ++49 (0)431 880-7300
www.uni-kiel.de/ufg
W115|58|2.4
N36|27|20.9
I guess that it should be
115:58:2.4W|36:27:20.9N
instead of
Benjamin
>grass command:
>error message:
>_______________________________________________
Archäoinformatik
D 24098 Kiel
Germany
www.uni-kiel.de/ufg
grass-dev mailing list
grass-dev@grass.itc.it
Markus Neteler <neteler itc it> http://mpa.itc.it/markus/
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
