[GRASS-dev] Re: [GRASS-user] v.in.db - dylb failure
Looks like that symbol isn't linking in from the mysql library. _all_charsets appears to be a "common" symbol, which is known to cause linking problems in OSX's default 2-level namespaces. Mysql is supposed to compile with the -fno-common flag on OSX, but for some reason this _all_charsets made it in there.
I'll see what I can do...
On Mar 10, 2008, at 5:21 PM, Richard Chirgwin wrote:
Greetings all,
I seem to be coming up with too many posts, for which I apologise!
This time, I have run into a v.in.db error on a colleague's machine. It's running William Kyngesburye's build (6.3 RC5 for Tiger) under OSX 10.4, and generating the following error:
dyld: Symbol not found: _all_charsets
Referenced from: /Applications/GRASS-6.3.app/Contents/MacOS/driver/db/mysql
Expected in: /Applications/GRASS-6.3.app/Contents/MacOS/lib/libgrass_dbmibase.dylib
Would this have something to do with directory links at start?
Richard
grass-user mailing list
grass-user@lists.osgeo.org
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
First Pogril: Why is life like sticking your head in a bucket filled with hyena offal?
Second Pogril: I don't know. Why IS life like sticking your head in a bucket filled with hyena offal?
First Pogril: I don't know either. Wretched, isn't it?
-HitchHiker's Guide to the Galaxy
I don't have anything I can easily test this on here, so can you try this:
http://www.kyngchaos.com/files/software/unixport/grass-mysql.zip
unzip it. Right-click the GRASS application and Show Package Contents. Dig into Contents/MacOS/driver/db and replace the "mysql" there with this one.
Greetings all,
Richard
grass-dev mailing list
grass-dev@lists.osgeo.org
"We are at war with them. Neither in hatred nor revenge and with no particular pleasure I shall kill every ___ I can until the war is over. That is my duty."
"Don't you even hate 'em?"
"What good would it do if I did? If all the many millions of people of the allied nations devoted an entire year exclusively to hating the ____ it wouldn't kill one ___ nor shorten the war one day."
<Ha, ha> "And it might give 'em all stomach ulcers."
- Tarzan, on war
