[GRASS-dev] Re: [GRASS-user] v.out.ogr multiple
Moving this over to grass-dev: is there a gisprompt for directories instead of files ?
Also, where can one see all the defined gisprompts for g.parser ?
Moritz
On 09/07/08 13:26, Gabriele N. wrote:
Thanks Moritz.
I have made some improvements.
I give you an example and the new script. Now I export all vectors with
name that starts with "foglio_1"
But I do not know how to select a folder where to export the shapes. Now,
only works if I enter the path by hand or select from a graphical user
interface a file in the folder (prova).
But it begins to work :slight_smile:
Still suggestions?
Thanks
Gabriele
http://www.nabble.com/file/p18359390/Schermata-v.out.ogr_multiplo.sh.png
Schermata-v.out.ogr_multiplo.sh.png http://www.nabble.com/file/p18359390/v.out.ogr_multiplo.sh
Moritz Lennert-2 wrote:
On 09/07/08 10:42, Gabriele N. wrote:
Hi Moritz.
On 08/07/08 22:33, Gabriele N. wrote:
Hello.
I want to create a script bash (GUI) to export many vector in shapefile
having the opportunity to decide which export layer (0, 1, 2) and
type=line,area ecc..
Does this mean interactive decision layer by layer, or that the module should allow for entering layer and type as an option ?
I would also like to know if you can use the characters as' * 'to be
able
to
export all instance vector starting with' nome_vector ....'.
There is already some scripts? If not, I started to write something in
bash
but I am in difficulty.
It will have to be something like:
for map in `g.mlist type=vect pattern=$GIS_OPT_PATTERN
   do
    v.out.ogr $map type=$GIS_OPT_TYPE layer=$GIS_OPT_LAYER
   done
where GIS_OPT_PATTERN would be something like 'nome_vector*'
If you need to automatically decide which layers and types to export, you might be able to do some grep/awk magic with v.category -g $map option=report.
Moritz
grass-user mailing list
grass-user@lists.osgeo.org
I would like to insert layer and type as an option.
Attached is what I have done (GUI and script). However, there are errors. http://www.nabble.com/file/p18356967/Schermata-v.out.ogr_multiplo.sh.png Schermata-v.out.ogr_multiplo.sh.png http://www.nabble.com/file/p18356967/v.out.ogr_multiplo.sh
Where I wrong?
It would be easier to help you if you gave us more information about the errors...
But from looking at your script, I already see this:
for map in g.mlist type=vect pattern=$GIS_OPT_PATTERN
should be:
for map in `g.mlist type=vect pattern=$GIS_OPT_PATTERN`
note the backticks (`)
and then
v.out.ogr input=${map} ...
should be v.out.ogr input=$map
Moritz
Moritz
instead of files ?
No.
gis_prompt() in lib/gis/parser.c.
However, that list isn't guaranteed to be exhaustive.
No.
Wouldn't it make sense to include one ? How hard is this ?
Could you elaborate on this ? :wink:
When writing a script, how can one know which options are available ?
Moritz
>> instead of files ?
> No.
Quite possibly.
How hard is this ?
AFAICT, you would need to add support in three places: gis_prompt()
(for terminal interaction), the Tcl/Tk GUI (lib/gis/gui.tcl), and the
wxPython GUI.
You can use any string you wish as the gisprompt value. Mostly,
G_parser() just passes that string along without interpreting it. If
the gisprompt string is not given or isn't recognised, the UI will
just expect the user to enter a string. Recognised values will result in a
more specific interaction; e.g. the terminal interaction may allow you
to obtain a list of valid answers by typing "list", the GUIs may
display a list of choices, etc.
