voice: 480-965-6262; fax: 480-965-7671
On Feb 12, 2008, at 12:17 PM, grass-user-request@lists.osgeo.org wrote:
Date: Tue, 12 Feb 2008 18:20:21 +0100
Subject: [GRASS-user] v.rast.stats error
To: grass-user@lists.osgeo.org
Message-ID: <47B1D555.9080506@amu.edu.pl>
Content-Type: text/plain; charset=ISO-8859-1; format=flowedHi
When runs v.rast stats with foolowing command:v.rast.stats -e vector=debs@LUBSKO layer=1 raster=depresions@LUBSKO
colprefix=dep percentile=90recive error:
ERROR:debs@LUBSKO_9432.0 is not in the current mapset (LUBSKO)
ERROR:An error occurred while converting vector to raster
G__open(r): mapset (LUBSKO) doesn't match xmapset (LUBSKO_9432.0)
ERROR:debs@LUBSKO_9432.0 is not in the current mapset (LUBSKO)everything seems clear, but why postfix: _9432.0 after mapset name??
Jarek
I just ran into the same issue today. The script checks to see if the map is in the current mapset and is not properly parsing the map@mapset format (debs@LUBSKO)
Delete the @mapset part and rerun this. It should work fine.
Michael
