On 11/04/07 13:48, Jarosław Jasiewicz wrote:
Moritz Lennert napisał(a):
On 11/04/07 13:01, Jarosław Jasiewicz wrote:
Hi
Is still possible to use pgSQL views to connect vectors?
Connecting views was possible for or five month ago (in spite of error messages during creating views).
I have some vector joinred to view They still working. But now, when I tried to connect new vector with view I recived simple error message that there is no table I plan to join
What is the exact error message you are receiving.
If that possibilites was removed (after my post, unfortunatly) please let me know
I am not aware of any related changes...
Sorry, I spoke to fast. I think I now found the culprit:
revision 1.40
date: 2006/11/28 08:42:02; author: markus; state: Exp; lines: +1 -1
if table doesn't exist: fatal error
Before it was only a warning, not a fatal error, and so the connection was established and worked.
This undoes what Radim did two years earlier:
revision 1.24
date: 2004/11/25 13:15:47; author: radim; state: Exp; lines: +2 -2
error -> warning if table does not exist
Markus, what was the reason that you changed this ?
Either we have to revert this again, or we have to find a way to check for views as well as tables, which means either implementing db_view_exists() (with all the individual implementations, or just modify the list_tables functions of the individual drivers to include views. In the PostgreSQL driver, the statement used is ( ):
"select * from pg_tables where tablename !~ 'pg_*' order by tablename"
For views this would have to be something like:
SELECT viewname FROM pg_views WHERE schemaname NOT IN ('pg_catalog','information_schema') AND viewname !~ '^pg_';
So the results of these two calls would have to be combined before db__driver_list_tables() returns the results.
I don't know if there are any good reasons not to just include views into the list of tables...
In the meantime, you can just modify v.db.connect at line 231 from
G_fatal_error(_("Table <%s> does not exist in database <%s>"),dbtable->answer, dbdatabase->answer);
to
G_warning(_("Table <%s> does not exist in database <%s>"),dbtable->answer, dbdatabase->answer);
BTW:
Pg Views are very important for me when I connect-reconnect vector files to different atribute table. I use (used!) views insted of original table to avoid occasional removing original data and to speed up transfer limiting data in views only to these needed for
(sorry, I think everybody knows it)
I completely agree with you. Being able to connect maps to views is fundamental in my eyes.
Moritz
