[GRASS-dev] Re: [GRASS-user] wxgui issue
voice: 480-965-6262; fax: 480-965-7671
On Feb 12, 2008, at 10:00 AM, grass-user-request@lists.osgeo.org wrote:
Date: Tue, 12 Feb 2008 14:28:55 +0100
From: Nikos Alexandris <nikos.alexandris@felis.uni-freiburg.de>
Subject: Re: [GRASS-user] wxgui issue ( No module named wx)
To: Carlos "Gu?no" Grohmann <carlos.grohmann@gmail.com>
Cc: GRASS List <grassuser@grass.itc.it>
Message-ID: <1202822935.6475.9.camel@vertical>
Content-Type: text/plain; charset="utf-8"
Just a POSITIVE comment!
The new GUI looks awesome!
Great job!
Where should I direct my "wishes"?
I miss the "add cell values layer"... :wink:
Cheers to all wxgrass developers!
Thanks for the positive words on behalf of all of us working on this.
The cell values layer won't work currently because it depends on the region resolution matching the resolution of the raster map.
(Perhaps this could be changed???)
Because the display resolution stays constant (regardless of the underlying computational resolution) in order to render MUCH faster, this means that even if you zoom in to a few cells, d.rast.num thinks you have too many cells to display and won't work. I hope there is a way to get around this eventually.
Michael
