[GRASS-dev] Re: [GRASS-windows] compiling WINGrass Python Scripts - ExpatError
-------- Original-Nachricht --------
Datum: Wed, 7 Dec 2011 21:23:13 +0000
Von: Glynn Clements <glynn@gclements.plus.com>
An: Johannes Radinger <JRadinger@gmx.at>
CC: grass-dev@lists.osgeo.org, grass-windows@lists.osgeo.org
Betreff: Re: [GRASS-windows] compiling WINGrass Python Scripts - ExpatError
Johannes Radinger wrote:
> I tried to run the script now manually with --help
> from the command line. For simplicicity I only tried
> v.krige.py, a python script that already comes with
> the GRASS 6.5 SVN install.
v.krige.py isn't a normal Python script; it has its own GUI.
I just meant that it comes already with GRASS so that I can be sure
that the source of the error is not my own script!
> I also tried to run my own script without the .py ending and with
--help:
> pythontest_l --help
> Traceback (most recent call last):
> File "C:\OSGeo4W\apps\grass\grass-6.5.svn\scripts\pythonte
> st_l.py", line 42, in <module>
> import grass.script as grass
> ImportError: No module named grass.script
You need:
  set PYTHONPATH=%GISBASE%\etc\python;%PYTHONPATH%
7.0 does this automatically, but 6.x doesn't.
Where do I have to set this permanently in Windows? Do I have modify a certain file? I'd need to use also my system python (2.6) and its modules within the script - will there be conflict?
Although the combination GRASS 6.x, Windows and Python isn't well tested I want to give it a try - as a tester....:slight_smile:
/johannes
> What is the normal way to run a python script in windows, with or
> without the .py ending?
I don't know. GRASS 6.x, Windows, and Python isn't a particularly
well-tested combination.
NEU: FreePhone - 0ct/min Handyspartarif mit Geld-zurück-Garantie!
Jetzt informieren: http://www.gmx.net/de/go/freephone
certain file?
have a look in C:\Program Files (x86)\GRASS 6.4.SVN\etc\env.bat
Helmut
View this message in context: http://osgeo-org.1803224.n2.nabble.com/compiling-WINGrass-Python-Scripts-ExpatError-tp7062790p7074085.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
> You need:
I suspect that GRASS' Init.bat or env.bat files are the appropriate
place. There's no reason to set it system-wide (i.e. outside of
GRASS).
On Thu, 08 Dec 2011 13:03:36 +0100
"Johannes Radinger" <JRadinger@gmx.at> wrote:
Hi Johannes, list,
as Glynn said, the module is quite different from other GRASS modules,
as it has its own GUI and calls another software (R) in the background.
It was built as a proof of concept, and many details are very
experimental. After integration in core I wasn't able to continue
development with the same pace, but I plan to.
all the best,
Anne
http://gis.cri.fmach.it/ghisla/
