[GRASS-dev] Re: [GRASS-windows] No such file or dire
------- Forwarded message follows -------
The 'About' window says
GRASS GIS 6.4.0svn (2009)
GIS Library Revision 37101 (2009-05-10)
I downloaded and installed on 02-Aug.
Peter
On 14 Aug 2009 at 16:54, Hamish wrote:
[r.in.poly fails to read text input file on Windows/CMD line]
I have checked at the r.in.poly source code, the problem does
not seem to be there. The path is passed to fopen() verbatim.
what version/revision of 6.4.0svn is this? is it the latest?
ISTR that Martin&Glynn had fixed this -- wxGUI now uses a
python parser which understands shell quoting on the Cmd> line.
But that might only be present in the very latest build.
Hamish
grass-windows mailing list
grass-windows@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/grass-windows
------- End of forwarded message -------
Hamish:
[r.in.poly fails to read text input file on Windows wxGUI Cmd> line]
I'm having a hard time finding that in SVN now... ??
Peter:
(we are trying to stabilize especially the library so its rev may stay
the same for several versions)
but Aug 2 is a few days into the latest version of Colin's package, so
you'll be using the latest version. Our field laptop just came back from
the field so I can now test the same.
I can reproduce the error; I can also reproduce the error in Linux if
I take the odd step of putting a '\' in the filename.
Workaround 1:
Just use the File-> Import raster -> import lines and polygons from ASCII
file GUI.
Workaround 2:
On the Cmd> line you need to quote the '\' character in the path names
with another '\', for example:
  r.in.poly input=C:\\Grassdata\\polygon.txt
the trouble is that '\' is the verbatim-character-follows quoting
character, disabling it could cause other issues (dealing with spaces
in path names for example). I had though that we were now using the
Python native path parser, but as mentioned above I can't find that in
the code now. I can see how C:\\path\\to\\file would get annoying quite
quickly on Windows.
Hamish
Hamish wrote:
Workaround 2:
a less bizarre but equally effective way to quote it:
   r.in.poly input="C:\Grassdata\polygon.txt"
:slight_smile:
Hamish
