You can use Python 2.4 or 2.5.
You must have wxPython 2.8 or higher.
Python and wxPython version numbers are not in sync with each other.
wxPython version numbers are (I think) in sync with wxWidgets version
numbers (since wxPython is built on wxWidgets).
If you have Python 2.4, you must compile wxPython for Python 2.4 (or get a
binary that is compiled for Python 2.4)
If you have Python 2.5, you must compile wxPython for Python 2.5 (or get the
proper binary).
I recently saw come across the list the comment that wxPython 2.8 will work
fine with things that need wxPython 2.6 (although the reverse is not true of
course).
Hope this clarifies things somewhat.
Michael
On 8/8/07 5:50 AM, "Tim Michelsen" <timmichelsen@gmx-topmail.de> wrote:
Thanks for your response.
As the errors indicate, you seem to have a mismatch between your wxPython
and Python version. You need to have a version of wxPython 2.8 that uses the
same version of Python you have on your computer--either 2.4 OR 2.5.How do I solve this mismatch?
How do I tell wxgrass which version to take?I need wxpython 2.4 for audacity, wxpython 2.6 for filezilla...
All these versions make it really confusing...
I am open for any hint!
Director of Graduate Studies
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
