On Tue, 14 Feb 2006 05:06:20 +0000
Glynn Clements <glynn@gclements.plus.com> wrote:
Tom Russo wrote:
> Back in October there was a discussion of how ps.map had a hard
> coded setting of 75DPI for its output, and a bit of a discussion of
> fixing that.
> I just spent a bunch of time trying to make postscript map files of
> some fairly high-quality map scans, only to have them come out
> looking blotchy. Only just now did I remember this discussion and
> look it up in my mail archives.
> Has there been any more thought about how to do away with this
> hard-coded limit in ps.map? The temporary solution is to rebuild
> ps.map with a different, higher hardcoded resolution, which is
> icky, to say the least (but easy, and that's what I did).
Sorry, I didn't realise it was still there. The latest CVS version no
longer downsamples raster maps.
grass6/ps/ps.map/read_cfg.c still has two "PS.res = 75;" statements.
> > fixing that.
Can these safely be removed?
Nothing appears to read PS.res, so it should be safe, although the
field should be removed altogether rather than left uninitialised.
