(I've already sent this message yesterday, but it didn't make it to the
list, thus resending)
Hamish, All,
Improved (still to be improved further) v.flip 1.1 is attached. Please
take a look at my writing below.
On Mon, 15 May 2006 15:29:03 +1200
Hamish <hamish_nospam@yahoo.com> wrote:
some hints follow,
<snip>
Maciek wrote:
2. I use "v.clean tool=snap thresh=0.01" to re-connect the flipped
and the remaining original lines. Is it 100% robust? No risk that
some won't be connected?
If anything I would make thresh much smaller so that no new lines are
snapped. The coordinates should not be changed unless you did printf %f
from awk (shortens decimal precision, use %s to output full input
string instead of proccessing as a number). So snapping should be
exact.
I see. I don't do any maths on coordinates, I only use awk to select
particular lines from v.out.ascii output and pipe them into another
file, in a given order, so I should be on the safe side here.
Is it possible to estimate what treshold should be enough? 0.0001,
else???
eval `g.findfile element=vector file="$INPUT"`
if [ ! "$file" ] ; then
can be shortened, g.findfile returns 1 if the file wasn't found.
see r.blend:
http://freegis.org/cgi-bin/viewcvs.cgi/grass6/scripts/r.blend/r.blend?rev=HEAD
just leave those tests out for input= and output=, g.parser checks
that maps do/don't exist given the rules in "#% gisprompt :",
--overwrite, etc.
These are cool, thanks. Done.
Call temporary maps like tmp_vflip_$$_toflip:
tmp_${PROG} makes it easy to spot orphans, $$ gives it a 1 in 32k
chance of being unique.
I'm already using $$, I think (TMP="`g.tempfile pid=$$`"). Is this
what you mean? Added $PROG, thanks.
It is easier to read, if instead of
output=$OUTPUT"_toflip"
you do
output=${OUTPUT}_toflip
or
output="${OUTPUT}_toflip"
Is the 1st one error prone or only "not nice"?
Is any of the 2 you recommend better? I'll correct my script
accordingly.
you probably want to use "sort -n" instead of "sort" so you don't get
1
13
2
20
etc.
In my case it doesn't matter - I only need to put identical words one
after another to filter out only 1 instance of each of them with uniq.
asis=`cat $TMP.cat_asis`
asis=`echo $asis | sed 's/ /,/g'`
probably hit the limitied size cap for a shell variable? (4096 chars?)
Use a tmp file.
Hmm, $asis is an input in the line 129:
v.extract -t layer=$LAYER input=$INPUT list=$asis output=
$OUTPUT"_leaveasis"
list= has to be a single, long string of numbers separated with ",". So
even if I avoid hitting the 4096 chars limit of a bash variable by
doing all in a TMP file, I will finally have to pass it to "v.extract
list=" as a one string, which will make it fail if the string is
longer than 4096 (is my thinking correct?).
A possible workaround would be to to convert long, continous sets
like eg. 1,2,3,4,5,...,100 into 1-100 and so on to save space. Is there
an easy way of doing it?
for a in $start_stop
do
done
make it easier to follow by indenting the inner part of the loop by a
few spaces.
see also v.out.ascii.db (wiki add-ons) and v.in.garmin (complex awk+tac
vector ascii format flipping to count vertices) scripts.
Thank you very much for all the hints. I really appreciate your help.
Best,
Maciek
W polskim Internecie s? setki milion?w stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.panoramainternetu.pl/
(attachments)
v.flip_11 (4.86 KB)
