On Mar 8, 2008, at 1:38 AM, grass-dev-request@lists.osgeo.org wrote:
Date: Fri, 7 Mar 2008 16:06:13 -0800 (PST)
Subject: Re: [GRASS-dev] Current state of GUIs on Win32
To: grass-dev@lists.osgeo.org
Message-ID: <714751.56317.qm@web45803.mail.sp1.yahoo.com>
Content-Type: text/plain; charset=iso-8859-1Michael Barton wrote:
The current GUI is based on TclTk 8.4.14 or so. As some people have
noted, it may work with 8.5, but there is no guarantee about it.
Given that we are replacing this GUI, I don't think it is worth the
effort to update the GUI to 8.5.IMO we should at least attempt to support Tcl/Tk 8.3 - 8.5.
For 8.3 there is just the one problem with v.digit, AFAIK.
For 8.5 it apparently mostly works, if it is just a few little issues
which are not so hard to fix, then we should try and solve them.
i.e. we should at least look into 8.5 problems, it is probably just 1-5
lines of code to be adjusted, and that's not a huge drain on
development resources.
You are right that fixing issues is probably pretty simple. It's figuring out what to fix that is time consuming. Right now, I'm heavily overcommitted timewise. And on top of that, I'm using my laptop (primary development box) for my GIS class and can't afford to have GRASS broken for more than a couple days. So I have no problem in theory, fixing the GUI for 8.5 if it doesn't involve NVIZ internals or something like that, but won't have time to do much for awhile.
Michael
