Hi Markus
Ok I finally managed to understand better what is happening.
i.pr.Training- Interactive option is failing. Non-interactive requires GRASS sites points. So far, I was able to do a testing dataset using interactive. What is failing in interactive? Not displaying image
i.pr.features- I fixed what was not working
i.pr.model- I believe it's working
i.pr.classification- Not working, at least for kNN. Doind some debugging...
Subject:
Re: [GRASS-dev] Re: i.pr in GRASS6.4
Markus Neteler <markus.neteler@iasma.it>
Date:
Wed, 19 May 2010 12:23:49 +0200
To:
grass-dev@lists.osgeo.org
To:
The MAN manual building script is either not existing on
your machine or perl fails:
GRASS_PERL=/usr/bin/perl VERSION_NUMBER=6.4.0svn sh /usr/local/grass-6.4.0svn/tools/g.html2man/g.html2man /usr/local/grass-6.4.0svn/docs/html/i.pr.blob.html /usr/local/grass-6.4.0svn/man/man1/i.pr.blob.1 1
sh: Can't open /usr/local/grass-6.4.0svn/tools/g.html2man/g.html2man
make[3]: *** [/usr/local/grass-6.4.0svn/man/man1/i.pr.blob.1] Error 2
That's harmless for the usage.
For the rest, there are warnings which should ideally be fixed but
warnings are not necessarily errors.
Perhaps you would just try the tools?
On 05/18/2010 04:41 PM, António Rocha wrote:
Ups forgot the attachment.. Sorry
All executables were created...
I'm sorry but I need to make a correction regarding this. This was done for GRASS6 so Makefiles will be similar to the ones that GRASS6.4 has.
Ok I have downloaded i.pr into my LINUX (Ubuntu machine) and I've used this command to compile:
sudo make -C i.pr MODULE_TOPDIR=/usr/local/grass-6.4.0svn &>log.log
Attached to this email is the installation LOG. I had a few errors, regarding Description.html but how is the rest? OK?
(will it work on GRASS6.4?)
Thank you
best regards,
Antonio Rocha
Greetings all
I've seen a few emails, at GRASS users mailing list regarding i.pr module. This module, developed for GRASS5 by Stefano Merler , is a multi-tool to perform Classification for a wide set of methods. This is a good asset for GRASS having this tool "fully working" on GRASS 6.4.
has anyone tried to "redone" this tool to GRASS6.4.?
Thank you so much for your help
Best regards,
Antonio Rocha
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5130 (20100519) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
Hi António,
please consider to submit your changes as "svn diff" to enable others
to make use of the improved i.pr.*.
thanks
2010/5/20 António Rocha <antonio.rocha@deimos.com.pt>:
Hi Markus
Subject:
Date:
To:
To:
Thank you
best regards,
Antonio Rocha
Greetings all
Best regards,
Antonio Rocha
http://www.eset.com
grass-dev mailing list
