Georg wrote:
Georg Kaspar wrote:
> this could be corrected by replacing the constant 255
with a variable according to the encoding of the image.
> i'm not quite shure how to do this (only did some
scripting so far) - can somebody help?
see also 'gdalinfo -stats' on raw data and 'r.info -r' on grass
maps.
where is rgb2his.c, I don't see it in grass 6.5
if that is a C module, ideally the 256 should be made a
module option which defaults to 256.
see attached patch x6.5, I'm not quite sure if the approach is
right though so haven't applied it.
Also, for a long time I have wanted to replace the quick
sexidecimal method with propper cone geometry math, but not
found the time. It doesn't seem too hard, and computers are
much faster these days.
to be more precise: how can i read-out the encoding of a
raster file (or the maximum value) in c? I already took a
look at the programmer's manual but didn't find what i'm
looking for (i'm accustomed to javadoc...).
from d.legend:
struct Range range;
struct FPRange fprange;
if (!fp) {
if (G_read_range(map_name, mapset, &range) == -1)
G_fatal_error(_("Range information for <%s> not available (run r.support)"),
map_name);
G_get_range_min_max(&range, &min_ind, &max_ind);
if (G_is_c_null_value(&min_ind))
G_fatal_error(_("Input map contains no data"));
else { /* is fp */
if (G_read_fp_range(map_name, mapset, &fprange) == -1)
G_fatal_error(_("Range information for <%s> not available"),
map_name);
G_get_fp_range_min_max(&fprange, &dmin, &dmax);
but the max value should be the channel's max, not the observed
max, so I think the module option is better.
as for dull greys, the grey255 color map is there to force min=0
max=255. If you want grey66535 just copy the 255 file and edit
to suit.
Hamish
(attachments)
i_rgb_his_depth.diff (5.03 KB)
