[GRASS-dev] Re: Line of Sight Update
Hi Will/Laura
(Cc grass-dev)
Some comments in-line below.
On Wed, 9 Jul 2008, Will wrote:
Hi again everyone,
I agree, it will be easy, but I wanted to make sure it was wanted before I
did it. I'll put it in now.
I have the code written for curvature when it runs in memory, but I have not
tested it to see if it works.
I'll do whatever we all think is best.
-Will
On Wed, Jul 9, 2008 at 12:05 PM, Laura Toma <ltoma@bowdoin.edu> wrote:
Will,
It will be very easy to add an option for the user to specify the elevation
of the observer. I think you should do it.
From what you told me, you are already considering the curvature of the
earth when you compute elevations? right?
How does the earth curvature calculation work? Does it just involve reducing the height of elevation cells based on their distance from the observer and the earth's ellipsoid before considering them in the calculation? GRASS has a function G_get_ellipsoid_parameters() to get the current radius and eccentricity squared of the earth's ellipse - is that relevant? Using that would make sure the calculation would still work correctly if someone used it on the Moon or Mars I suppose. It would also need to function correctly (i.e. be disabled) in an XY (unprojected) location. But maybe all this is something we can look at later.
(There are also some functions G_meridional_radius_of_curvature(), G_transverse_radius_of_curvature() and G_radius_of_conformal_tangent_sphere() which may or may not be relevant.)
Regarding the output: my suggestion was to output, for every cell that is
visible, its height (or slope) *above* the line of sight; this will give
an indication of how visible the point is. Similarly, for the cells that
are *not* visible, you could compute their height (or slope) below the line
of sight. High positive values will mean the point is very visible; high
negative values will mean the point is very un-visible.
I don't quite understand what "the line of sight" is here. What I think of as the line of sight is a straight line from the observer to the visible cell, passing straight through both. Some kind of output relating to how visible the cell is definitely sounds like a very good idea though.
Paul
visible, its height (or slope) above the line of sight; this will give
are not visible, you could compute their height (or slope) below the line
I don’t quite understand what “the line of sight” is here. What I think of as the line of sight is a straight line from the observer to the visible cell, passing straight through both. Some kind of output relating to how visible the cell is definitely sounds like a very good idea though.
Sorry, I meant the height/slope above or below the horizon. In other words, at a point p, in addition to boolean visibility, we can compute
the height difference between p and the lowest point at that location that would be visible by the observer.
-Laura
