[GRASS-dev] Re: module problem in wxgui
Martin,
xmlproc is not available on my Mac version of Python 2.5. See below. I've
got xml.dom, xml.etree, xml.parsers, and xml.sax.
Within xml.parsers is only expat
cmb-MBP-2:~ cmbarton$ python
Python 2.5.1 (r251:54869, Apr 18 2007, 22:08:04)
[GCC 4.0.1 (Apple Computer, Inc. build 5367)] on darwin
Type "help", "copyright", "credits" or "license" for more information.
import xml.parsers
import xml.parsers.xmlproc
  File "<stdin>", line 1, in <module>
ImportError: No module named xmlproc
help(xml.parsers)
Help on package xml.parsers in xml:
NAME
    xml.parsers - Python interfaces to XML parsers.
FILE
/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/xml/parsers/
__init__.py
MODULE DOCS
    http://www.python.org/doc/current/lib/module-xml.parsers.html
DESCRIPTION
    This package contains one module:
    expat -- Python wrapper for James Clark's Expat parser, with namespace
             support.
PACKAGE CONTENTS
    expat
Michael
On 10/22/07 12:35 AM, "Martin Landa" <landa.martin@gmail.com> wrote:
2007/10/22, Michael Barton <michael.barton@asu.edu>:
Hi Martin,
I'm trying to get gis_set.py to work. I came across this error in trying to
start up.
   File
"/Applications/Grass/GRASS-6.3.app/Contents/MacOS/etc/wx/wxgui.py",
line 33, in <module>
     from xml.parsers.xmlproc import xmlproc
I have xml.parsers but not xml.parsers.xmlproc
xml.parser.xmlproc is currently used for validation of grc xml
workspace file. xmlproc should be standard part of python-xml.
Martin
Michael
Director of Graduate Studies
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
phone: 480-965-6213
fax: 480-965-7671
Hi Micheal,
2007/10/23, Michael Barton <michael.barton@asu.edu>:
Martin,
>>> import xml.parsers
>>> help(xml.parsers)
NAME
FILE
__init__.py
MODULE DOCS
DESCRIPTION
             support.
PACKAGE CONTENTS
    expat
hm, strange, xmlproc should be part of python-xml package. For now I
disable xmlproc...
Martin
Michael
> Hi,
>> Hi Martin,
>> start up.
>> File
> Martin
>> Michael
>> phone: 480-965-6213
>> fax: 480-965-7671
phone: 480-965-6213
fax: 480-965-7671
Martin Landa <landa.martin@gmail.com> * http://gama.fsv.cvut.cz/~landa *
I am not sure if there is a replacement for xmlproc which can be used
for validation of xml file. I found useful only xmlproc. expat seems
to be a non-validation parser.
"xmlproc is a Python native parser that performs nearly complete
validation. If you need a validating parser, xmlproc is currently your
only choice in Python. Further, xmlproc provides a variety of
high-level and experimental interfaces that other parsers do not."
For now xml validation is disabled...
Martin
Martin,
>>> import xml.parsers
>>> help(xml.parsers)
NAME
FILE
__init__.py
MODULE DOCS
DESCRIPTION
             support.
PACKAGE CONTENTS
    expat
Michael
> Hi,
>> Hi Martin,
>> start up.
>> File
> Martin
>> Michael
>> phone: 480-965-6213
>> fax: 480-965-7671
phone: 480-965-6213
fax: 480-965-7671
On Oct 23, 2007, at 2:35 AM, Martin Landa wrote:
PACKAGE CONTENTS
    expat
disable xmlproc...
I just looked at the python documentation on the python site, and the only parser in the "standard" package is expat.
xmlproc is an extra from the pyxml package.
http://pyxml.sourceforge.net/
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"I ache, therefore I am. Or in my case - I am, therefore I ache."
- Marvin
