[GRASS-dev] Re: MS-Windows native GRASS
On Mon, Sep 18, 2006 at 11:15:23AM +0100, Glynn Clements wrote:
Huidae Cho wrote:
> $env(GRASS_HTML_BROWSER) $env(GISBASE)/docs/html/$pgm_name.html &
> So we can define:
> proc g_manual {pgm} {
> global env
> exec $env(GRASS_HTML_BROWSER) $env(GISBASE)/docs/html/$pgm.html &
> We need a generic way to call programs including shell scripts and
> binary files (e.g., sh -c 'cmd args'). Is grass-xterm-wrapper used only
> for interactive programs or can we use this for non-interactive ones
> too?
grass-xterm-wrapper is only used for programs which require a
terminal. It should not be used for non-interactive programs, as gis.m
needs to read the process' output.
> We have a Windows version of grass-xterm-wrapper which can
> be used in both ways.
That's a mistake. As the name implies, grass-xterm-wrapper is supposed
to be a front-end to an xterm-like terminal program. Its sole purpose
is to allow terminals other than xterm to be used for programs which
require a terminal. Once we eventually eliminate the need to use a
terminal, it will go away altogether.
I agree, rxvt may be more suitable for the wrapper. But, curses based
modules (I didn't count how many modules actually depend on this library)
don't work with rxvt and that's why I chose cmd.exe for winGRASS. For
example, grass -text doesn't work in rxvt.
Huidae
cmd.exe isn't a terminal emulator, it's a shell. Windows automatically
creates consoles for console-mode programs such as cmd.exe (unless you
use "start /b ...").
While *something* needs to be done on Windows, the solution *doesn't*
involve grass-xterm-wrapper. Which is why I've reverted the recent
attempt to replace grass-xterm-wrapper (it was getting compiled on
Linux, where it totally won't work; there is no sh.exe on Linux).
Note that it wouldn't have worked on Windows either, as it made no
attempt at escaping shell metacharacters.
Probably, that is because of cross-compiling or wrong definition of
MINGW in include/Make/Platform.make? If the solution doesn't involve
grass-xterm-wrapper, what could be done for Windows *now*? If there are
no alternative ways of getting terminals working on Windows, I think
it's better to keep it until someone comes up with a better idea
although you may not like it.
As you mentioned above, no modules should require any user interaction
if they're called from within GUI. Otherwise, there would be no way to
make a platform independent GUI.
No, it's because you have a target named grass-xterm-wrapper, and a
source file named grass-xterm-wrapper.c which is older than the
target, so make assumes that it's supposed to compile and link
grass-xterm-wrapper.c into grass-xterm-wrapper.
If the solution doesn't involve grass-xterm-wrapper, what could be
I'm not sure that anything *can* be done for Windows right now, other
than "this feature doesn't work on Windows yet".
GRASS has two decades of history as a Unix package. Getting a native
Windows version working isn't going to happen overnight. And trying to
rush it will only make things harder in the long run.
If there are
Running a command in a terminal and handling shell scripts are
separate issues. Running a binary executable in a Windows console
shouldn't involve sh.exe in any way.
More significantly, the problem of running scripts on Windows isn't
limited to whether or not they are run in a terminal. Even
non-interactive scripts need special treatment. On Unix, the first
argument to execve() can be a binary executable or a script, and the
kernel will handle the details. This doesn't work on Windows, which
doesn't recognise the #! syntax.
Shell scripts need to be run via sh.exe (but *not* via "sh -c ...").
But we don't really want to have to hardcode knowledge of whether a
particular program is a binary or a script into gis.m.
Essentially, all calls to "exec" (or "open |...") in Tcl need to be
modified to allow scripts to work under Windows. This requires a
"launcher" which would determine whether the command is a binary or
script based upon the first few bytes of the file (scripts begin with
#! then the interpreter, Windows executables begin with "MZ"), and
invoke the interpreter if necessary.
You would need to map the path, as a "/bin/sh" probably won't be found
at "C:\bin\sh.exe". One option is to look for an association for ".sh"
in the registry (HKEY_CLASSES_ROOT\.<ext> for the type, then
HKEY_CLASSES_ROOT\<type>\shell\open\command for the handler).
Note that grass-xterm-wrapper *isn't* suitable as a launcher, as it is
only used for commands which need to be run in a terminal.
Confirmed. You mean "*newer* than the target."
> If there are
When sh.exe does that interpretation, why do we need another launcher?
Is it because of metacharacters? What side effects can we expect if
sh.exe is used to run binary files?
Out of curiosity, is just adding ".sh" to the registry enough to run
*.sh through sh.exe?
Huidae
Yes.
> > If there are
Mostly, although there may be other issues. A shell is an extremely
heavy-weight solution.
Also, using sh.exe isn't exactly "native" Windows, IMHO. Obviously, if
we have shell scripts, then we need a shell to execute them. But we
shouldn't need it (and shouldn't be using it) for anything else.
It doesn't help that all of the shells which I've encountered perform
various Unix-compatibility tasks (e.g. translating filenames between a
virtual Unix filesystem and the native Windows filesystem). This
creates a risk of undesirable side-effects (e.g. filenames being
converted in some contexts but not in others, resulting in
mismatches).
What side effects can we expect if sh.exe is used to run binary
files?
There are two ways that the shell can be used. As an interpreter for
shell scripts, and as a mechanism for executing commands ("sh -c").
The latter is inappropriate on Windows, and not even a good idea on
Unix (where its normally used due to laziness). It's far more robust
to use the OS' mechanism(s) (execve(), spawnl()) directly.
Using the shell as an interpreter for shell scripts is safe, e.g.:
  spawnl("sh.exe", "script", "arg1", "arg2", NULL);
However, this only works for shell scripts; if you pass the name of a
binary file in the above example, the shell will attempt to interpret
it as a shell script, which obviously won't work.
OTOH, using:
  spawnl("sh.exe", "-c", command, NULL);
requires that command be constructed from the name of a program and
its arguments, and that isn't as simple as concatenating the strings
with spaces in between. The simplest solution to the issue of
metacharacters is to replace any occurrences of the single quote
character in arguments with "'\''" (quote, backslash, quote, quote)
and surround each argument with single quotes.
Even then, there might be issues due to the shell messing with the
environment, signal handling, process groups etc (as well as possible
Unix-compatibility "features"). Shells are very complex programs.
I don't think you can map extensions directly to programs; normally,
the extension is mapped to a file type, then various actions are
associated with the type. E.g. ".vbs" is mapped to "VBSFile", then
actions are registered for "VBSFile".
OTOH; it's by no means guaranteed that the registered handler will do
the right thing. E.g. the "open" handler for .sh files might be a text
editor, or it might run them in a new console or an rxvt. In that
case, we might need a $GRASS_SH variable for Windows.
So far, I've been just a lurker on this discussion. It still seems that most
of the fundamental changes to make compiling a Windows native GRASS will
still be outside the GUI per se. But when this is worked out and if there
still needs to be some changes in the TclTk code, let me know if I can help.
Michael
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
Date: Wed, 20 Sep 2006 20:38:02 +0100
To: Huidae Cho <grass4u@gmail.com>
Cc: Michael Barton <michael.barton@asu.edu>, <grass-dev@grass.itc.it>
Subject: Re: [GRASS-dev] Re: MS-Windows native GRASS
Yes.
If there are
mismatches).
files?
OTOH, using:
One change that I want to see is to define g_manual or something to
avoid running g.manual directly from within gis.m. As mentioned before,
help_cmd invokes a user specified browser to show help pages. Only
thing g.manual does in gis.m is simply helping a browser to display html
files, so there is no reason to use g.manual script when we have a
better alternative that works platform independently. Current Help menu
(g.manual) doesn't work in Windows, but the GRASS help icon in each
module's dialog box works (help_cmd).
Thank you,
Huidae
Michael
phone: 480-965-6213
fax: 480-965-7671
> From: Glynn Clements <glynn@gclements.plus.com>
> Yes.
>>>> If there are
> mismatches).
>> files?
> OTOH, using:
