[GRASS-dev] Re: need a truly quiet quiet
On Nov 1, 2007, at 5:49 PM, grass-dev-request@grass.itc.it wrote:
Initial Comment:
I have just experienced, how expensive it can be, to write a WARNING out for every point, when buffering. I try to build simple buffers (only 8 points needed) around a lot of points - in one case 370.000 - and for the reason I choose a high tolerance value (to be sure, it will be reset to the max allowed one). THis works, but takes unbelievably long with all the warnings:
“WARNING: The tolerance was reset to …”
Now I have commented out the warning in main.c of v.buffer, and suddenly it is running like mad (30 seconds instead of over 10 minutes). So maybe it would be nice to :
  • either add another switch to turn off this warning
  • or include it under the “–quiet” option (NO warning if “–quiet” set).
Andras Fabian
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=188&aid=525&group_id=21
Andras,
I really really agree with you. This has been an endless source of problems for me trying to script a GUI around modules that will not be quiet.
Michael
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
> "WARNING: The tolerance was reset to ..."
> - either add another switch to turn off this warning
> - or include it under the "--quiet" option (NO warning if "--quiet"
> set).
be quiet.
With the exception of Tcl's exec and open| treating stderr output as
an error, scripts shouldn't care whether modules are writing anything
to stderr.
If a script has problems with modules writing to stderr, that's the
fault of the script, not the module.
