i have the same problem (nviz crash)
to avoid any conflict with other libraries that i’ve installed on my mac (intel machine)
i formatted the HD
i installed osx on it
Xcode and GCC
now i’m tring to buid grass on a fresh osx 10.4.9 installation
(so i’m sure that there is not external library or
somethink like fink-darwinports environment that can be a possible conflict)
to install grass as first step,
i installed the tcltk library (8.14) from source as suggested in the readme file.
then i tried to configure grass63-cvs =
cvs downoad …
cd …/grass6
make distclean
./configure --prefix=/Applications --enable-macosx-app --enable-sysv
–with-x
–with-opengl=x11
–with-cxx
–with-freetype
–with-freetype-includes=/Library/Frameworks/FreeType.framework/unix/include
–with-freetype-libs=/Library/Frameworks/FreeType.framework/unix/lib
–with-gdal=/Library/Frameworks/GDAL.framework/Versions/1.4/Programs/gdal-config
–with-proj-includes=/Library/Frameworks/PROJ.framework/unix/include
–with-proj-libs=/Library/Frameworks/PROJ.framework/unix/lib
–with-proj-share=/Library/Frameworks/PROJ.framework/Resources/proj
–with-jpeg
–with-jpeg-includes=/Library/Frameworks/UnixImageIO.framework/unix/include
–with-jpeg-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib
–with-tiff
–with-tiff-includes=/Library/Frameworks/UnixImageIO.framework/unix/include
–with-tiff-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib
–with-png-includes=/Library/Frameworks/UnixImageIO.framework/unix/include
–with-png-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib
–with-sqlite
–with-sqlite-libs=/Library/Frameworks/SQLite3.framework/unix/lib
–with-sqlite-includes=/Library/Frameworks/SQLite3.framework/unix/include
–with-fftw
–with-fftw-includes=/Library/Frameworks/FFTW3.framework/unix/include
–with-fftw-libs=/Library/Frameworks/FFTW3.framework/unix/lib
–with-postgres-includes=/usr/local/pgsql/include
–with-postgres-libs=/usr/local/pgsql/lib
–with-tcltk-includes=/usr/local/tcltk/include
–with-tcltk-libs=/usr/local/tcltk/lib
–x-includes=/usr/X11R6/include/
–x-libraries=/usr/X11R6/lib/
–with-python
–enable-largefile
export TCLTKPREFIX=/usr/local/tcltk/
make
sudo make install
.configure give me not errors
idem with make
butr try to use nviz … it crash!
again i tried to configure grass with the same .configure,
but in usr/local instead of /application :
./configure --prefix=/usr/local/ …(without : --enable-macosx-app ) …
i’ve the same results (nviz crash)
note:
using the --prefix=/usr/local
grass start with a native aqua gui and no x11
(can this hep to indagate the nviz problem ?)
Massimo.
Il giorno 09/mag/07, alle ore 17:24, grass-dev-request@grass.itc.it ha scritto:
I did make distclean before compiling. On the binary nviz is still crashing
