[GRASS-dev] Re: nvizlib compile error
Are we at a place yet where I can compile and test this on a Mac, given it's location of OpenGL in the agl directory?
Michael
On Jul 9, 2008, at 12:36 AM, <grass-dev-request@lists.osgeo.org> <grass-dev-request@lists.osgeo.org > wrote:
Date: Tue, 08 Jul 2008 18:48:05 +0200
From: Moritz Lennert <mlennert@club.worldonline.be>
Subject: [GRASS-dev] nvizlib compile error
To: grass-dev <grass-dev@lists.osgeo.org>
Message-ID: <48739A45.3050606@club.worldonline.be>
Content-Type: text/plain; charset=windows-1252; format=flowed
I get an error trying to compile lib/nviz on a Debian system with a
fresh SVN checkout of trunk:
"~/SRC/GRASS/grass_trunk/lib/nviz$ make
gcc
-I/home/mlennert/SRC/GRASS/grass_trunk/dist.i486-pc-linux-gnu/include
-Wall -g -O2 -fPIC -DPACKAGE=\""grasslibs"\" -I/usr/include
-I/home/mlennert/SRC/GRASS/grass_trunk/dist.i486-pc-linux-gnu/include -o
OBJ.i486-pc-linux-gnu/cplanes_obj.o -c cplanes_obj.c
In file included from cplanes_obj.c:19:
/home/mlennert/SRC/GRASS/grass_trunk/dist.i486-pc-linux-gnu/include/grass/nviz.h:31:4:
error: #error Unsupported platform, or confused platform defines...
/home/mlennert/SRC/GRASS/grass_trunk/dist.i486-pc-linux-gnu/include/grass/nviz.h:113:
error: expected specifier-qualifier-list before ‘Display’
make: *** [OBJ.i486-pc-linux-gnu/cplanes_obj.o] Erreur 1"
- configure output shows:
checking for location of OpenGL library...
checking for glBegin in -lGL... yes
checking for gluBeginCurve in -lGLU... yes
checking for glXCreatePbuffer... yes
checking for glXCreateGLXPixmap... yes
OpenGL support: yes
Moritz
I think there may still be some GLx vs AGL vs WGL differences to take care of? At least, I'm now getting this:
In file included from change_view.c:20:
/Users/Shared/src/GRASS/svn/trunk/dist.i386-apple-darwin9.3.0/include/grass/nviz.h:120: error: syntax error before ‘AGLPixelFmtID’
/Users/Shared/src/GRASS/svn/trunk/dist.i386-apple-darwin9.3.0/include/grass/nviz.h:120: warning: no semicolon at end of struct or union
/Users/Shared/src/GRASS/svn/trunk/dist.i386-apple-darwin9.3.0/include/grass/nviz.h:122: error: syntax error before ‘windowId’
/Users/Shared/src/GRASS/svn/trunk/dist.i386-apple-darwin9.3.0/include/grass/nviz.h:122: warning: data definition has no type or storage class
/Users/Shared/src/GRASS/svn/trunk/dist.i386-apple-darwin9.3.0/include/grass/nviz.h:127: error: syntax error before ‘}’ token
make: *** [OBJ.i386-apple-darwin9.3.0/change_view.o] Error 1
Checking with -E, I see that I'm getting the "struct render_window" as expected, so I don't know what's wrong. Maybe that should be a typedef? since render_window is used in render.c as:
struct render_window* Nviz_new_render_window();
Michael
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"I ache, therefore I am. Or in my case - I am, therefore I ache."
- Marvin
The code won't compile on a Mac at present.
AFAICT, it requires at least:
    /* TODO */
- rwin->displayId = aglChoosePixelFmt(GDHandle *dev, int ndev, attributeList);
+ rwin->displayId = aglChoosePixelFmt(NULL, 0, attributeList);
- rwin->contextId = aglCreateContext(rwin->display, NULL);
+ rwin->contextId = aglCreateContext(rwin->displayId, NULL);
    /* create win pixmap to render to (same depth as RootWindow) */
- rwin->pixmap = NULL; /* TODO */
+ rwin->pixmap = <no idea what should go here, but it ain't NULL>;
There is some information on AGL at:
[1] http://www.mesa3d.org/brianp/sig97/agl.txt
[2] http://www.mesa3d.org/brianp/sig97/compare.htm
but I don't know how much of that refers to "classic" rather than OSX.
There's a lot more information in visualization/nviz/src/togl.c, but
it doesn't include creating off-screen pixmaps.
I also note:
[3] http://www.iua.upf.es/~ggeiger/redbookhtml/apc.html
  Off-screen Rendering
  To render off-screen, first create an off-screen graphics
  world in the usual way, and pass the handle into
  aglCreateAGLPixmap().
Good luck on figuring out what "the usual way" is :wink:
A Google search for aglCreateAGLPixmap produces exactly 7 hits; I've
just posted three of them, and the other 4 seem to be duplicates of
[1] and [3].
IOW, everything that mentions aglCreateAGLPixmap seems to assume that
you are already familiar with normal (non-OpenGL) Mac GUI programming.
In any case, it's going to require some amount of trial and error from
someone with a Mac.
Thanks much William. Sounds like it's getting closer to working on a Mac.
Michael
____________________
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
Michael
- Marvin
thanks for the hits. I have commited some changes [1].
However I have no access to Mac. Needs some investigation how to make
off-screen rendering working.
Martin
[1] http://trac.osgeo.org/grass/changeset/32068
2008/7/10 Glynn Clements <glynn@gclements.plus.com>:
   /* TODO */
I also note:
[1] and [3].
someone with a Mac.
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
Martin,
I'm more than happy to test and report, but I have to at least get it compiled. It seems like it's getting closer.
Michael
Phone: 480-965-6262
Fax: 480-965-7671
On Jul 9, 2008, at 11:24 PM, Martin Landa wrote:
Martin
[1] Changeset 32068 – GRASS GIS
  /* TODO */
I also note:
[1] and [3].
someone with a Mac.
2008/7/10 Michael Barton <michael.barton@asu.edu>:
well, render.c is used only by nviz CLI module. To test wxGUI nviz
extension you can compile the library without render.c
cd lib/nviz/
rm render.c
make clean
make
cd gui/wxpython/nviz
make clean
make
g.gui &
Martin
I'll give it a try.
Michael
Phone: 480-965-6262
Fax: 480-965-7671
On Jul 9, 2008, at 11:41 PM, Martin Landa wrote:
cd lib/nviz/
rm render.c
make clean
make
make clean
make
g.gui &
Martin
-- Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
