[GRASS-dev] Re: [OSGeo] #216: Fighting Bandwidth Accelerators
  Reporter: warmerdam | Owner: warmerdam
      Type: task | Status: reopened
  Priority: normal | Component: SAC
Resolution: | Keywords:
Comment (by hamish):
FWIW I was seeing this even though I have not done anything so rude as to
bump up the max connection per ip in my browser. I think that simply "3"
is too agressive.
hmm. In Debian/stable's Firefox 2.0 if you go to "about:config" and filter
on
connection you will see:
network.http.max-connections-per-server default int 8
network.http.max-persistent-connections-per-proxy default int 4
network.http.max-persistent-connections-per-server default int 2
same values in the epiphany browser.
Markus:
> Seems to help.
same here.
thanks,
Hamish
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/216#comment:7&gt;
OSGeo <http://www.osgeo.org/&gt;
