#37: grass: wxpython gui issues
Reporter: jachym | Owner: osgeo4w-dev@lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone:
Component: Package | Version:
Resolution: | Keywords: GRASS
Comment (by hamish):
Hi, just attempting my first OSGeo4W GRASS install. Downloaded today.
packaging issues re. the wxpython GUI & epsg file:
wxPython Startup: [Create new location from EPSG code]
Error window:
"Unable to read EPSG codes: [Errno 2] No such file or directory:
u'/c/OSGeo4W/share/proj\\epsg'
[Ok], Choose EPSG Code window comes up.
Path to the EPSG-codes file: [c/OSGeo4W/share/proj\epsg]
[Browse], find it in the above location, [Ok]
Error window:
Unable to read EPSG codes: string index out of range
[Ok]
but if I know the number and put it in, it accepts it and expands to the
correct +proj terms. (I tried # 4326 ll/wgs84)
So it's just the code browser which is unhappy in the end. But without
browsing to fix the "/c/...\epsg" to "C:\...\epsg" it gives me a Traceback
error in the DOS console (line 1567 KeyError: 4326).
the rest is probably generic wxPy GUI RFE issues, but while I'm at it...
Set default region extent and resolution window:
[tab] does not advance from North box to S -> W -> E -> Res.
no preview on map-of-the-world, and can't drag a semitransparent box to
set NSWE values automatically.
Trying again with EPSG # 27200 (NZMG).
Select datum transforms: drop down menu with 1,2,3. That's not very clear:
perhaps the descriptive text could be bolded or in a box with a brighter
background or someway to highlight that is the pertinent info.
The GRASS GIS Layer Manager window still says '(Experimental Prototype)'
in the title bar. I thought we already got rid of that? [this is 6.4.0rc3]
cheers,
Hamish
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/37#comment:19>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
