#37: grass: wxpython gui issues
Reporter: jachym | Owner: osgeo4w-dev@lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone:
Component: Package | Version:
Resolution: | Keywords: GRASS
Comment (by marisn):
Replying to [comment:24 hamish]:
> Path to the EPSG-codes file: /c/OSGeo4W/share/proj/epsg
> if you click "browse EPSG codes", you get an error that the file can't
be found. If you browse for the EPSG file, the path becomes
`C:/OSGeo4W/share/proj/epsg` and then it all works: ie the nice code table
browsing, searching, & grabbing.
Path in Tcl/Tk is taken from env variable: GRASS_PROJSHARE that is set
during compilation(?). Make it correct on Windows and there will be no
error messages.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/37#comment:25>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
