Von: OSGeoLive <trac_osgeolive@osgeo.org> Gesendet: 31. August 2019 17:38:31 OESZ Betreff: Re: [OSGeoLive] #2181: GRASS freezes when using r.import on file without projection
Reporter: johanvdw | Owner: osgeolive@…
Type: defect | Status: new
Priority: major | Milestone: OSGeoLive13.0
Component: OSGeoLive | Resolution:
Keywords: grass |
Changes (by kalxas):
* keywords: => grass
* cc: osgeolive@… (added)
* priority: minor => major
* type: task => defect
* milestone: => OSGeoLive13.0
Ticket URL: <[https://trac.osgeo.org/osgeolive/ticket/2181#comment:3](https://trac.osgeo.org/osgeolive/ticket/2181#comment:3)>
OSGeoLive <[http://live.osgeo.org/](http://live.osgeo.org/)>
self-contained bootable DVD, USB thumb drive or Virtual Machine based on Lubuntu, that allows you to try a wide variety of open source geospatial software without installing anything.
Keywords: grass |
The reason was that r.import did not change back to the original location + mapset by resetting GISRC. Fixed in master, relbr78, and relbr76, also for v.import.
