[GRASS-dev] Re: path name containing spaces - error on windows 7
Hi Helmut,
---------- Forwarded message ----------
To: grass-dev@lists.osgeo.org
Cc:
Date: Wed, 21 Dec 2011 04:50:25 -0800 (PST)
Subject: [GRASS-dev] Re: path name containing spaces - error on windows 7
Margherita wrote:
I’m reporting an error on behalf of a student.
She tried to install Wingrass 6.4RC2 on her
Windoze 7 machine and got the following error[1]
how was it installed? right click and “run as admin”?
No, just double click on it… Is this the right way to install it?
On Wed, Dec 21, 2011 at 12:51 AM, Hamish
the error message is because MSys doesn’t like
to be in C:\Program Files\ (it wants to be in e.g.
C:\osgeo4w) and comes from mswindows/osgeo4w/msys.bat
but, GRASS-Packager.bat should have run:
rem delete msys.bat from osgeo4w because there is an adaption (for spaces
in installation path) written >by GRASS-Installer.nsi
del %PACKAGE_DIR%\msys\msys.bat
this adapted msys.bat wasn’t touched more than a year or so.
The problem is both in WinGRASS-6.4.2RC2-1-Setup.exe from [1] and on daily
WinGRASS-6.4.SVN-r49821-1-Setup.exe from [2].
Problem raises starting GRASS. Then, GRASS starts without the terminal.
I haven’t tried these above mentioned wingrass-installer-version here on my
win7-64bit-box, I’ll try it. but I had not any problems with daily builds on
this win7-64bit-box
Other students have installed the above mentioned versions as well without problems. The problem raises only on one machine. And this makes very hard to understand the possible cause. Any idea/hint/test proposal are very welcome.
Thank you.
madi
Helmut
View this message in context: http://osgeo-org.1803224.n2.nabble.com/path-name-containing-spaces-error-on-windows-7-tp7112888p7115041.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
Eng. Margherita Di Leo
Ph.D. Candidate
Methods and Technologies for Environmental Monitoring
Department of Environmental Engineering and Physics (DIFA)
University of Basilicata
Campus Macchia Romana
85100 - Potenza
Office: +39-0971205360
   how was it installed? right click and "run as admin"?
No, just double click on it.. Is this the right way to install it?
just a double click is "normal" on WinVista/Win7 (the wingrass should ask
automatically for admin rights for install), but on winxp a right click and
"run as admin" is required to have rights for installing in C:\Program
Files, it's an very old issue here on the windows side. :frowning:
unfortunately and contrary to linux, in windows - also in WinVista/Win7 -
there can be a lot different flavours how rights to install in C:\Program
Files are set.
just give it a try with a right click and run as admin ...
problems. The problem raises >only on one machine.
unfortunately I can't reproduce it here neither on my WinVista-32bit nor on
my Win7-64box.
best regards
Helmut
View this message in context: http://osgeo-org.1803224.n2.nabble.com/path-name-containing-spaces-error-on-windows-7-tp7112888p7119993.html
