To: grass-dev@lists.osgeo.org
Cc:
Date: Thu, 22 Dec 2011 13:05:03 -0800 (PST)
Subject: [GRASS-dev] Re: path name containing spaces - error on windows 7how was it installed? right click and “run as admin”?
No, just double click on it… Is this the right way to install it?
just a double click is “normal” on WinVista/Win7 (the wingrass should ask
automatically for admin rights for install), but on winxp a right click and
“run as admin” is required to have rights for installing in C:\Program
Files, it’s an very old issue here on the windows side.unfortunately and contrary to linux, in windows - also in WinVista/Win7 -
there can be a lot different flavours how rights to install in C:\Program
Files are set.just give it a try with a right click and run as admin …
Same result, not solved.
madi
Eng. Margherita Di Leo
Ph.D. Candidate
Methods and Technologies for Environmental Monitoring
Department of Environmental Engineering and Physics (DIFA)
University of Basilicata
Campus Macchia Romana
85100 - Potenza
Office: +39-0971205360
