[GRASS-dev] Re: photo.* and description.html
(moving to list)
On Sun, May 3, 2009 at 9:54 AM, Hamish <hamish_b@yahoo.com> wrote:
in GRASS 6 I get:
Following modules are missing the 'description.html' file
in src code:
photo.elev
photo.target
Can we blacklist them in tools//build_html_index.sh? Or bad
side effects?
both those have skip-me overrides in their Makefiles:
htmletc:
@echo no docs needed for $(PGM)
That seems to be ignored here? But yes, see below:
as recently as 6.4.0rc3 they built correctly without generating a
photo.*.tmp.html file and "Following modules are missing the
'description.html' file" complaints.
this is the result of r36693 for Module.make
http://trac.osgeo.org/grass/changeset/36693
specifically
$(MAKE) htmletc
+ $(MAKE) manetc
htmletc is bypassed but manetc is not.
I see.
I am not sure if manetc: should check if htmletc: was run, or if the
Makefiles should override both htmletc: and manetc:, or something else.
Since manetc depends on a previous htmletc run, it should perhaps
check (not sure how).
partly because I'm not sure how the new manetc logic works: does it now
build each man page as it goes,
Yes, in case there is only one (so not for r.mapcalc and a few others).
in addition to rebuilding them after
the end of the compile? or is that only meant for individual module
rebuilds sometime later?
The global man creation catches all left-over cases such as
r.mapcalc/r3.mapcalc.
because the Makefiles already say "skip me" I think fixing the build
toolchain is more correct than putting them on the build_html_index
bypass list and ignoring the problem.
OK - so we need more magic in the man part.
RC3:
photo.elev$ make
Makefile:15: warning: overriding commands for target `htmletc'
.../../../include/Make/Html.make:53: warning: ignoring old commands for target `htmletc'
make htmletc
make[1]: Entering directory `/usr/local/src/grass/grass-6.4.0RC3/imagery/i.ortho.photo/photo.elev'
no docs needed for photo.elev
make[1]: Leaving directory `/usr/local/src/grass/grass-6.4.0RC3/imagery/i.ortho.photo/photo.elev'
RC4:
photo.elev$ make
make htmletc
make[1]: Entering directory `/usr/local/src/grass/grass-6.4.0RC4/imagery/i.ortho.photo/photo.elev'
make[1]: Leaving directory `/usr/local/src/grass/grass-6.4.0RC4/imagery/i.ortho.photo/photo.elev'
make manetc
make /usr/local/src/grass/grass-6.4.0RC4/dist.i686-pc-linux-gnu/man/man1/photo.elev.1 MANSRC=/usr/local/src/grass/grass-6.4.0RC4/dist.i686-pc-linux-gnu/docs/html/photo.elev.html
make[2]: Entering directory `/usr/local/src/grass/grass-6.4.0RC4/imagery/i.ortho.photo/photo.elev'
make[2]: `/usr/local/src/grass/grass-6.4.0RC4/dist.i686-pc-linux-gnu/man/man1/photo.elev.1' is up to date.
make[2]: Leaving directory `/usr/local/src/grass/grass-6.4.0RC4/imagery/i.ortho.photo/photo.elev'
Yes, it was added after RC3 to simplify the installation of GRASS Addons
(all I have implemented to have a local "make install" target which is
convenient
for Addons and local recompilations in a production system).
