[GRASS-dev] Re: Possible to update to 6.4 stable on UbuntuGIS ppa repo?
Isaac wrote:
I'm not sure who maintains the compiled binaries on the
ubuntugis ppa repository,
Often packages filter in straight from DebianGIS (thanks to
Francesco Lovergine), but the UbuntuGIS packages are shepherded
in by Alan Boudreault. Coordination for UbuntuGIS is on the
ubuntu at lists.osgeo dot org mailing list.
  https://wiki.ubuntu.com/UbuntuGIS
so I'm addressing this request to the whole list. Currently,
the version of GRASS64 on the ppa is RC6-2. Given that 64
stable has just been released, it would be nice to have the
stable version put up to the PPA.
we're working on it, I expect it will be in UbuntuGIS's unstable
ppa soon.
For whatever reason the weekly snapshot does not install
correctly on Ubuntu (hasn't for some time now). It always
spews out a proj error when you launch GRASS.
it's not entirely surprising that the binary snapshot would give
problems if the exact library versions were not in place same
as what the package was built with, even though the build platform
(debian/stable) is not too far from ubuntu.
I have tried today to compile 64 stable from source (on Ubuntu
10.04), but keep getting an annoying error during config that
it can't find my gdal libs (even though they are installed in
the normal place, and I've run ldconfig, etc..).
works for me,
./configure --with-tcltk-includes=/usr/include/tcl8.5 \
  --with-cairo --with-motif \
  --with-python=/usr/bin/python2.6-config --with-readline \
  --with-cxx --with-odbc --with-sqlite --with-freetype \
  --with-freetype-includes=/usr/include/freetype2 \
  --without-postgres --with-proj-share=/usr/share/proj \
  --enable-64bit --with-pthread \
  --with-wxwidgets=/usr/lib/wx/config/gtk2-unicode-release-2.8 \
  --with-geos
have a look at the end of the config.log file for clues.
Hopefully I'll be able to figure out the compile issues, but
regardless, it would be nice for Ubuntu users to have the
ability to install 64 stable through apt-get or the package
manager, and would be much less of a head ache to install than
compiling.
have a look at the package building instructions in the debian/
dir of the GRASS source code. It's almost a one-liner to make
your own .deb packages.
So I suppose this is a request to whomever it is that maintains
those packages to upgrade them to the current stable version...
no worries,
Hamish
