Frank:
> There is currently no way to find out the hardcoded location that
> proj will search for support files.
> >Hamish:
> >In GRASS we'd like to auto-locate & parse the EPSG file for quickly
> >defining new projects from the startup screen if given a valid
> >code. Usually libproj is found in the LD search path so our
> >./configure hasn't been told where to look. Knowing --prefix would
> >be enough I think, but PROJ_LIB is the path we want to know.
> Understood. If you would like to file a request for a proj-config,
> I will try to add it at some point, but it won't help you for quite
> a while.
Markus:
Probably we can only loop over common directories and check
if the epsg file is there unless a new proj-config becomes
available and distributed?
As probably 4 values will cover 90% of users, I think this is a
practical solution. I don't plan on adding a request for proj-config,
if someone else thinks it is a good idea please add the wish.
Hamish
