uses “6+” to signal that subsequent versions are intended to work. Since
the package only uses system(), it will work as long as
–interface-description returns an XML file. Plenty of examples and
scripts stop working because GRASS 6 and 7 modules have different flags
and/or parameter names, but in principle only for that reason. It’s hard
for me to check - it would be useful to have a translation table for flag
and parameter names by module where changes have occurred.
Best wishes,
Roger
Roger Bivand
Department of Economics, NHH Norwegian School of Economics,
Helleveien 30, N-5045 Bergen, Norway.
The idea to be least invasive while gaining maximal consistency.
I hope that only a few scripts/examples are failing after migrating
from GRASS 6 to 7.
uses "6+" to signal that subsequent versions are intended to work. Since
--interface-description returns an XML file. Plenty of examples and
and/or parameter names, but in principle only for that reason. It's hard
Best wishes,
Roger
Roger Bivand
Thanks, this may be helpful, but is misses small things like the name being the same but the representation changing. For example, in some v.* like v.info, the layer parameter in 6* is integer, but 7 wants character.
Those broke the R code, so spgrass6 has to branch on GRASS 6/7 version in these cases; others I've seen break example scripts. For script maintainers, it may be unavoidable that changes have to be made, I agree, but it can be puzzling.
Roger
Paulo
On 08/29/2012 02:50 PM, Helmut Kudrnovsky wrote:
fyi a question regarding an "translation" (flags,parameter) table between grass6x and grass7.
Helmut
-------- Original-Nachricht --------
Datum: Wed, 29 Aug 2012 14:35:37 +0200 (CEST)
Von: Roger Bivand
An: Helmut Kudrnovsky
Betreff: Re: R + grass7
Best wishes,
Roger
Roger Bivand
