Does this mean that we are abandoning the idea to have -g determine *how* out put is printed (i.e., shell-script style) and use other flags to determine *what* is printed?
Michael
____________________
C. Michael Barton
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Nov 27, 2011, at 10:00 AM, <grass-dev-request@lists.osgeo.org> wrote:
Date: Sat, 26 Nov 2011 17:50:39 -0800 (PST)
Subject: [GRASS-dev] Re: r49205 - in grass/trunk: lib/python
raster/r.info
To: Martin Landa <landa.martin@gmail.com>
Cc: GRASS developers list <grass-dev@lists.osgeo.org>
Message-ID:
<1322358639.73854.YahooMailClassic@web110016.mail.gq1.yahoo.com>
Content-Type: text/plain; charset=iso-8859-1Martin:
current situation is
r.info
? -g???Print raster array information only[in shell script style!]
? -e???Print extended metadata information only
[also in shell script style!]
v.info
? -g???Print region info in shell script style
? -e???Print extended metadata info in shell
script stylewhich forces to open discussion again.
..did it ever close?
what is new since last we discussed this is r.info's
many shell script style flags are now grouped* so
it is not as messy in the module GUI. IMHO it is a
good compromise, and consistent design among modules
is still respected.[*] Changeset 49293 – GRASS GIS
so -rgstmpud becomes -ger instead of just one huge
-g. Non shell-script safe foo=(bar) things are kept
in -e, so you can still `eval` -g. Instances of
'(none)' have been changed to '"none"' to become
more shell friendly as well.I would still incline to use `-g` for shell
script output as used in others modules.
I have counted more than 45 modules in trunk
which use `-g` for shell script style output.huh? I don't understand what you are talking about.
** r.info -g, v.info -g, and g.region -g DO all
print eval-safe shell script style ** same as ever,
still shell script style, still similar to -g in
other modules...Keep in mind that r.info and v.info's default
"pretty" output mode is a tractor-fed dot-matrix
printer style report, not a "foo: bar" listing. [and
fwiw there is no point for "min: 1.2345" instead of
"min=1.2345" style, since min= is perfectly human
friendly to read]What they are not is a full --parsable-debug-data-
dump which may save a gui programmer 5 keystrokes
in a python library which is revisited once every
3 years, but make things totally annoying for a
command line user who uses that same flag 20 times
a day, not to mention making them eval-unsafe.If you need a --dump-everything-parsable flag some-
where then fine add that (better yet just make a
wrapper --script instead of messing up the code),
but don't remove the fine grained eval-safe shell
script style options in the process. These things
do not have to be mutually exclusive. But -g does
have to stay shell-script (ie eval) safe.I don't see any reason why `r.info` or `v.info`
should be exceptions.?! they aren't !?
If you want to see an exception, look at d.what.rast
-t "terse" output flag.Hamish
