Glynn wrote:
AFAICT, there are two options:
1. The current region belongs to libraster; in which case,
G__ belongs in libraster, along with anything which uses it.2. The current region belongs to libgis; in which case, G__
needs to have the window and window_set fields moved back to
libgis, and everything which uses the remaining fields needs
to be moved to libraster.
for my 2c the region belongs to libgis, as it is also used for
display bounds and by region cropping input=/output= flags for
some vector modules.
Hamish
