Please see below
On Jul 26, 2008, at 2:57 AM, Martin Landa wrote:
2008/7/25 Michael Barton <michael.barton@asu.edu>:
I commented out the CheckForWx() line in globalvar.py and got the following
message...do you mean?
http://trac.osgeo.org/grass/browser/grass/trunk/gui/wxpython/gui_modules/globalvar.py#L52
This function is also called
gis_set.py:globalvar.CheckForWx()
gui_modules/menuform.py:globalvar.CheckForWx()
gui_modules/dbm.py:globalvar.CheckForWx()
gui_modules/globalvar.py:def CheckForWx():
gui_modules/globalvar.py:CheckForWx()
wxgui.py:globalvar.CheckForWx()ERROR: wxversion.select() must be called before wxPython is imported.
wxPython >= 2.8.1.1 is required. Detailed information in README file.
I can upgrade. But is this a good idea? Have you added something that only
works in the most recent version?Did you modify CheckForWx()? You need to call import wxversion before
you call wxversion.select()...Just try in python
import wxversion
wxversion.select(str(2.8))
import wx
wx.__version__'2.8.8.1'
This version check is failing with 2.8.8.0 on the Mac even if the correct version is installed. It may be failing with other version too. wx.__version__ looks for wxpython SOURCE (*.py) files that are not currently being included in the wxpython binary installer for some reason. The object files are correct and being installed (*.pyo).
Why not just use wx.version()? It gives the correct response regardless of whether the source files are installed or not.
Michael
if it's still not working for you, you should ask at wxPython ML. I
remember a few weeks ago we tried to solved it -- but you didn't
follow wxPython ML, seehttp://lists.wxwidgets.org/pipermail/wxpython-users/2008-July/077605.html
Regards, Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
