[GRASS-dev] Re: scientific notation
Hi Ivan,
fixed in CVS.
спасибо, Martin
2007/11/24, Ivan Shmakov <ivan@theory.asu.ru>:
>>>>> Martin Landa <landa.martin@gmail.com> writes:
>> I would like to import points data in GRASS (with v.in.ascii). My
>> data includes number written with the scientific notation (for
>> example 1.2e+23). During the import, I am defining them as double.
>> Unfortunately, it doesn't work...
>> I get the following message :
>> " ERROR: Column 9 defined as double has string values "
>> Can GRASS actualy deal with number written with scientific notation ?
>> Is there a specific way to deal with these numbers ?
> no, it seems, v.in.ascii doesn't support it...
        It seems that it's the is_double () function which behaves in a
        wrong way:
$ nl -ba grass-6.3.cvs_src_snapshot_2007_11_03/vector/v.in.ascii/points.c
    30 /* Determine if the string is double, e.g. 123.456, +123.456, -123.456
    31 * return 1 if double, 0 otherwise */
    32 static int is_double(char *str)
    33 {
    34 int i = -1, ndots = 0;
    35
    36 while (str[++i] != '\0') {
    37 if (i == 0 && (str[i] == '+' || str[i] == '-'))
    38 continue;
    39
    40 if (str[i] == '.') {
    41 if (ndots > 0)
    42 return 0; /* > 1 dot */
    43
    44 ndots++;
    45 continue;
    46 }
    47
    48 if (!isdigit(str[i]))
    49 return 0;
    50 }
    51
    52 return 1;
    53 }
        IIUC, the number is to be converted from its string
        representation by atof () later. Since, I assume, atof ()
        supports e-notation, there's no necessity in such a strict check
        like is_double () currently performs. Therefore, I suggest
        is_double () to be reimplemented on top of strtod () instead,
        e. g.:
static int
is_double (char *s)
  char *tail;
  if (strtod (s, &tail),
      tail == s || *tail != '\0') {
    /* doesn't look like a number,
       or has extra characters after what looks to be a number */
    return 0;
  return 1;
        BTW, is_int () could be rewritten as well.
Martin Landa <landa.martin@gmail.com> * http://gama.fsv.cvut.cz/~landa *
