Kim, probably you have a special character in your module/Option (such as á, à , ã or something). Right?
Because I'm using Ubuntu 9.10 and I have already coded a NDVI function, very similar to yours, and it's working just fine. as soon as I put a character like those, I get an error like
*(python:3562): Pango-CRITICAL **: pango_layout_get_cursor_pos: assertion `index >= 0 && index <= layout->length' failed*
and huge wxPython GUI error in command window.
Antonio
Subject:
Re: [GRASS-dev] Scripting in Linux
Kim Besson <kimbesson1981@gmail.com>
Date:
Tue, 26 Jan 2010 15:39:59 +0000
To:
Glynn Clements <glynn@gclements.plus.com>, grass-dev@lists.osgeo.orgTo:
CC:Yeah sure...
The following was printed in TERMINAL:
(python:2176): Gtk-CRITICAL **: gtk_widget_event: assertion `WIDGET_REALIZED_FOR_EVENT (widget, event)' failedAnd at the command output it was:
<?xml version="1.0" encoding="ANSI_X3.4-1968"?>
<!DOCTYPE task SYSTEM "grass-interface.dtd">
<task name="i.ndvi">
<description>
NDVI Calculus
</description>
<keywords>
DW-E, raster, imagery, vegetation
</keywords>
<parameter name="bandnir" type="string" required="yes" multiple="no">
<description>
raster input map (Near Infrared)
</description>
<gisprompt age="old" element="cell" prompt="raster" />
</parameter>
<parameter name="bandred" type="string" required="yes" multiple="no">
<description>
raster input map (Red)
</description>
</parameter>
<parameter name="ndvi" type="string" required="yes" multiple="no">
<description>
raster output NDVI map
</description>
<gisprompt age="new" element="cell" prompt="raster" />
</parameter>
<flag name="overwrite">
<description>
</description>
</flag>
<flag name="verbose">
<description>
Verbose module output
</description>
</flag>
<flag name="quiet">
<description>
Quiet module output
</description>
</flag>
</task>
(Tue Jan 26 15:38:40 2010) Command finished (0 sec)
This gives us any light?2010/1/26 Glynn Clements <glynn@gclements.plus.com <mailto:glynn@gclements.plus.com>>
Kim Besson wrote:
> But, for instance, I have just made a NDVI script (i.ndvi) and I
added the
> file to my script folder but I got the following error:> SAXParseException
> <unknown>:5:3: not well-formed (invalid token)
> Could you tell me what's wrong? Am I suppose to do something else?Can you post the output from "i.ndvi --interface-description" ?
<mailto:glynn@gclements.plus.com>>------------------------------------------------------------------------
grass-dev mailing list
http://lists.osgeo.org/mailman/listinfo/grass-dev__________ Information from ESET NOD32 Antivirus, version of virus signature database 4807 (20100126) __________
The message was checked by ESET NOD32 Antivirus.
