[GRASS-dev] Re: should G_raster_map_type() use G_find_cell2() ?
perhaps more to the point,
lib/gis/find_file.c
the Doxygen header comments for G_find_file() and G_find_file2()
each describe what the other function does.
are the functions correct or are the comments correct?
Hamish
lib/gis/find_file.c
You're misreading the comment for G_find_file2() (easily done, due to
the odd phrasing):
* Exactly the same as G_find_file() except that if name is in the
* form nnn in ppp, and is found, name is changed to nnn by G_find_file().
This is saying: G_find_file() changes the name, but this function
doesn't.
Glynn Clements wrote:
> lib/gis/find_file.c
the odd phrasing):
* the form nnn in ppp, and is found, name is changed to nnn by
G_find_file().
doesn't.
ahh, ok. I've updated the comments in CVS to be clearer.
Hamish
